My GE PSC23SGRSS fridge stopped cooling so i
Hi, you may have a problem with the compressor or the condenser fan motor behind the box getting hot and shutting off on external overload. Or, even better, you could have just a cord that isn't working well and not getting a good connection all of the time. Before I restocked it I would keep a close eye on it to see if this problem happens again. If it does, before you unplug it, try and roll it out to get behind it with out unplugging it, I know this might be difficult to do.You should have a lower fiber panel on it. Remove the screws and you will see a small fan, a small coil, and the brain, (compressor) there. If the fan is not on, and you can reach in and slowly lay your hand on the top of compressor as it may be very HOT, but check it to see if it is hot, warm, or cool like its been off. Now, where the cord comes in see if you can grab it and move it around to see if the fan and compressor tries to start or does. If so, get a new cord If not, then unplug it and back in. If it starts again, still get a new cord, as this is the problem. While you are back there, on the front side of the coil, try to clean all of the dust, lint, and what ever that's build-up over the years. This will save wear on the compressor as you will have air flow through the coil. Please keep me up dated on what has happened. I can help you more if you need me.
Sincerely,
Shastalaker7
