20 Most Recent
Lakewood 792/c Utility Heater Questions & Answers
What is the 750 w
It's twice the wattage output and will use almost twice as much electricity when heating. However, it will heat a larger area.
Lakewood heater 792/AA
sounds like a broken element or wire. with unit unplugged, using an ohm meter check all connections and check elements for resistance.
Have a Lakewood HV9 that died.
No. If my memory is correct it has a thermal fuse in the winding that opened. It was not designed to be replaced or repaired. Your berings froze up stalling the motor. It got hot and took out the fuse. You got a lot of years of good service from it.
I need wiring diagram for a Lakewood heater
try this link.
https://images.app.goo.gl/eqouF5WZLpQbu987
There are several diagrams for lakewood heaters.
Youb can also do a search google by typing in (wiring diagram for a Lakewood heater).
