20 Most Recent Arcade Alley Alley Electronic Double Hoop Questions & Answers
It is important to keep your practices fast paced. By doing each drill for no more than five minutes, you allow each player to maintain a high energy level without getting tired of the specific exercise.
Basketball | Answered on Jun 23, 2019
The first African American player to be drafted and play in the NBA was Earl Lloyd in 1950. In 1955, he even led his team to the championship.
Basketball | Answered on May 31, 2019
You should wash it on a regular cycle. It does not to be gentle because the fabric can take a lot of pressure and sometimes need it. You can even put the detergent directly on certain spots to get rid of stains. I just suggest that you don't use bleach and that you use cold water so that the colors don't run.
Basketball | Answered on May 21, 2016
https://m.youtube.com/watch?v=iwguLUWPGDc
Basketball | Answered on Apr 04, 2015
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Basketball | Answered on Jan 25, 2015
As a high school basketball coach for a girl's team, the first thing I always tell them is to not use hand lotion. This adds to excess slippery sweat on the palms. You should be gripping the ball between your palms. When you shoot it, instead of tossing it from your palms, throw it with your arms.
Basketball | Answered on Aug 11, 2014
African antelope list kewel, kob, kirks dik, klipspringer and kudu
Basketball | Answered on Apr 29, 2014
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
Basketball | Answered on Apr 16, 2014
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Basketball | Answered on Nov 11, 2013
Basketballs are made of mostly rubber with a fiber layer wrapped around them for protection. It depends on which league you are referring to but this is the standard.
Basketball | Answered on Oct 23, 2013
You need to give us a better picture and description of your problem. It looks like you are working with a basketball goal that is laying down on the ground. Do you really mean only the "Net," or are you using the word net to mean the whole backboard mechanism? Are you talking about hooking the strings of the net to the orange "hoop?"
Is this the first time you have tried to raise it, or has something changed after you have used it successfully for awhile? Is this new and you put it together yourself? If so, you probably made a mistake. Review the instructions, or ask a mechanical friend to look at it.
Often the answer is easy - its asking the right question that is the hard part! Hopefully you can understand that you have not yet asked us the right question.
Basketball | Answered on May 26, 2013
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Basketball | Answered on Feb 21, 2013
Arcade Alley Alley Electronic Double Hoop Logo
3 questions posted
Top Arcade Basketball Experts
Meli Dragon
Meli Dragon
Tom Chichester
Anon
Are you an Arcade Basketball Expert? Answer questions, earn points and help others
View Most Popular
Arcade Basketball
  • Arcade Basketball
Most Popular Question
get better grip ball when 39 m
  • Basketball
