20 Most Recent
GE Monogram® ZET1038 Single Oven Questions & Answers
Oven lights on Model ZET1038PF3SS
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/15/2010 5:09:20 PM •
GE...
Answered
on Aug 15, 2010
F1 error
Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook
Check oven temperature sensor for continuity. Replace if zero or infinite ohms
2/16/2010 2:48:06 AM •
GE...
Answered
on Feb 16, 2010
Oven Light Will Not Shut Off - GE Range Oven Model: PS968SP1SS
If you have already replaced the Hi-Amp Door Switch on your GE Range Oven (Model: PS968SP1SS), but the oven light still will not turn off, there are a few additional steps you can take to troubleshoot the issue:
- Check the light switch: Ensure that the light switch is functioning properly. It is usually located near the oven door frame or control panel. Press the switch manually to see if the light turns on and off. If it is not working, you may need to replace the light switch.
- Inspect the light socket: Examine the light socket for any signs of damage or corrosion. If the socket appears to be damaged, you may need to replace it.
- Verify the wiring connections: Check the wiring connections between the light socket, the Hi-Amp Door Switch, and the main control board. Ensure that all connections are secure and properly connected. Loose or faulty wiring can cause the light to stay on.
- Test the main control board: As you suspect, a faulty main control board could also be the cause of the issue. You can try resetting the control board by turning off the power to the oven at the circuit breaker for a few minutes and then turning it back on. If the light still does not turn off, it may indicate a problem with the control board that requires replacement.
If you have performed these troubleshooting steps and the light still won't turn off, it would be advisable to contact GE customer support or a qualified technician for further assistance. They will be able to diagnose the problem more accurately and recommend the appropriate solution.
6/18/2023 4:55:39 PM •
GE Ovens
Answered
on Jun 18, 2023
