20 Most Recent
GE SCB2001FSS Advantium Electric Single Oven Questions & Answers
Advantium noisy fan
It is probably the external cooling fan that is causing the problem, as this is usually the first one to come on, and the last one one to stop., and usually, these are located at the top of the unit.
My GE Profile Advantium Microwave
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
Advantium oven has no power
THE NEXT STEP IS TO CHECK THE OUTLET FOR POWER, THEN THE CORD WHERE IT ATTACHES TO TO OVEN ITSELF. A VOLT METER IS MOST RECOMMENDED FOR THIS, AS THERE MAY BE A BURT WIRE OR BAD PLUG.
How to replace the oven sensor
order your sensor from local supply house, 2 screws inside oven cavity, any luck itll pull right through and you be able to re=plug the new one, if not remove the back panel and unplug it from there2 screws nad one plug no prob at all
Oven Light Will Not Shut Off - GE Range Oven Model: PS968SP1SS
If you have already replaced the Hi-Amp Door Switch on your GE Range Oven (Model: PS968SP1SS), but the oven light still will not turn off, there are a few additional steps you can take to troubleshoot the issue:
- Check the light switch: Ensure that the light switch is functioning properly. It is usually located near the oven door frame or control panel. Press the switch manually to see if the light turns on and off. If it is not working, you may need to replace the light switch.
- Inspect the light socket: Examine the light socket for any signs of damage or corrosion. If the socket appears to be damaged, you may need to replace it.
- Verify the wiring connections: Check the wiring connections between the light socket, the Hi-Amp Door Switch, and the main control board. Ensure that all connections are secure and properly connected. Loose or faulty wiring can cause the light to stay on.
- Test the main control board: As you suspect, a faulty main control board could also be the cause of the issue. You can try resetting the control board by turning off the power to the oven at the circuit breaker for a few minutes and then turning it back on. If the light still does not turn off, it may indicate a problem with the control board that requires replacement.
If you have performed these troubleshooting steps and the light still won't turn off, it would be advisable to contact GE customer support or a qualified technician for further assistance. They will be able to diagnose the problem more accurately and recommend the appropriate solution.
6/18/2023 4:55:39 PM •
GE Ovens
Answered
on Jun 18, 2023
