20 Most Recent
GE Profile JK915 Electric Single Oven Questions & Answers
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
GE Profile JK915...
Answered
on Nov 26, 2014
Hi, Consumer. We're sorry to hear about the difficulty with your oven. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps!
http://bit.ly/112Lu7q
GE Profile JK915...
Answered
on Jun 06, 2014
Has this just happened or have you suddenly just tested the oven temperature with a RELIABLE thermometer? Some cheaper thermometers can give a false reading. Check with a accurate thermometer first and place it at intervals in different parts of the oven ( it does vary) and take the average
GE Profile JK915...
Answered
on Jan 19, 2014
oven display element supply all working perfectlyonly 1 problem i face oven did not heat up...plz help me quicklythank youRegardedHannan Ashraf
GE Profile JK915...
Answered
on Jan 01, 2013
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
GE Profile JK915...
Answered
on Oct 07, 2012
1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
or
1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
GE Profile JK915...
Answered
on Nov 22, 2011
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
thats what a F2 code is on a GE
GE Profile JK915...
Answered
on Jul 15, 2011
It sounds like somethin did burn, likely a wire, and it has "gone to ground" and tripped the breaker. If the breaker will only reset momentarily, it is doing it's job, and it is telling you that a hazard exists. It is probably time to call a serviceman, or someone who is comfortable with appliance repair. Good luck, Rob
GE Profile JK915...
Answered
on Jan 01, 2011
First you need to remove all four burners' bases, so the cook top assembly which is one unit to be clean and by removing the secure screws you can lift up the whole unit. If there is some dry burned oil around it can be stuck but you can use a straight screwdriver as a lever to force it up.
Now you have clear underneath burner manifold pipe with orifice and air valve control so you can clean and adjust.
However my advice is to use a thin pin or a metal wire to clean the burner orifice first since if it is dirty the gas pressure is lower and you have the same blackening problems. If after that you still have the same problem then you can adjust the air valve.
Here below we have a link with the parts layout of your range so it will help you dismantle the cook top assembly and know before how is your range.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203190&diagram_id=22289624#d22289624
GE Profile JK915...
Answered
on Sep 30, 2010
Hello there:
Normally this is due to a bad temperature sensor
F3
Open oven
temperature sensor
circuit
Measure oven
temperature sensor
circuit at oven temperature sensor (should be approx
1100
ohms at room temp); check for cut or pinched wire or
loss
of contact and replace if found faulty
GE Profile JK915...
Answered
on Apr 30, 2010
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
GE Profile JK915...
Answered
on Sep 21, 2009
I flipped the breaker so that it would go back to its original settings and that worked
GE Profile JK915...
Answered
on Aug 24, 2009
it is the connector for the ribbon cable on the back of the control panel. I bought a new panel as well and figured out it is the ribon cable connector in the back doesn't hold the ribbon well . I am looking for the part to replace it on line with no luck yet ( the whole board area is 178.00 us dollars so i just want the 5 dollar or so ribbon cable connector to soder in.
GE Profile JK915...
Answered
on Dec 02, 2008
GE code F97. We had power blips for several days, then tried to start the oven and got this code. Turned breaker off for a minute with no luck. Turned "clean" mode on for lower oven, and BINGO!!! The lower fan started up. Canceled clean mode. Ovens then worked OK with no error code!
GE Ovens
Answered
on Apr 06, 2021
