20 Most Recent GE Profile JT915 Electric Single Oven Questions & Answers
use stop/clear reset clock then
GE Profile JT915... | Answered on Jul 22, 2019
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
GE Profile JT915... | Answered on Mar 14, 2016
Hello, Welcome to FixYa.
I'll start by saying on many models different issues can manifest a similar scenario, especially under the same manufacturer. For instance the error code "F0" on GE built ranges means either the timer/control is faulty or a key on the user interface/ketpad is stuck.
There is a somewhat easy method to determine which is at fault though, if you are mechanically inclined, or even confident to pull the back off with guidance.
**Unplug the unit from the wall or turn off the breaker (40amps)...safety first**
The keypad connects to the timer by way of whats called a "ribbon connector" or "molex connector", if you disconnect the keypad from the timer then restore power wait at least 40-60 seconds and the "F0" returns, you need the control/timer. If no error occurs, re-connect the ribbon connector, restore power and then if the "F0" returns, its the keypad/control panel.
OVEN CONTROL/Timer
KEYPAD
Keep me posted as to what you find or if this is something you think you can or can't do. I'll await your next post and we'll go from there. I will help you in any manner I can of course. Thank you for choosing FixYa for your inquiry.
Regards,
Macmarkus :)
GE Profile JT915... | Answered on Oct 06, 2013
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more than this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
GE Profile JT915... | Answered on Dec 12, 2011
Hello there and thank you for choosing fixya
The f-3 code is a verry common code on ovens what this is telling you is that the oven temperature temperature sensor is not working correctly they normally will read the preheat then fail shortly after this and produce the code that you are recieving ok?
So you will first want to check to see that the temperature sensor is fully connected and is in good condition if it looks bad or full of grease or junk clean it and then try it again this may help but if not you will need to replace it ok?
Hope this is very helpful for you
Best regards Mike
GE Profile JT915... | Answered on Jun 29, 2011
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
GE Profile JT915... | Answered on Apr 16, 2011
It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
Hope I helped.
GE Profile JT915... | Answered on May 07, 2010
1-800-gecares
GE Profile JT915... | Answered on Dec 29, 2007
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
I think your ignition does not work.
Is this a brand new oven ?
Does it have a stove on top ?
does the stove work ?
Sounds like a bimetal switch is blown. first I would check SWITCH LIMIT BIMETAL next the LIMIT SWITCH-UPPER(LOCK) Too check them first trip the breaker so you don't have power to the oven, then you will have to take the oven out of the wall..next remove the top cover. then in the center-front there are two round bimetal switchs with two wires coming out of them..remove the wires and check them with an ohm meter both should have continuity across them ...if no continuity you have a bad switch. let me know what you find out..
GE Profile JT915... | Answered on Aug 26, 2007
GE Profile JT915 Electric Single Oven Logo
16 questions posted
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
bought oven thermometer indicates
  • Ovens
