20 Most Recent GE ZSC2001FSS Advantium Electric Single Oven Questions & Answers
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
GE ZSC2001FSS... • Answered on Sep 02, 2017
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
GE ZSC2001FSS... • Answered on Jun 04, 2015
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
GE ZSC2001FSS... • Answered on Jun 28, 2012
Hello, thank you for posting your question on Fixya. I will be helping you with your Advantium oven. From your description it sounds like your having problem with the oven arcing. While you are using your microwave you can only have arcing occur while you are using the microwave or speedcook feature. While in either mode attention must be given to any mental in the oven. When microwaving place food and containers on the white ceramic tray only. The metal pan should be used during speedcook.
Happy Holidays!
Please rate "4 thumbs" if this was helpful.
GE ZSC2001FSS... • Answered on Dec 23, 2010
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
GE ZSC2001FSS... • Answered on Jul 03, 2010
F3 This code usually means that the oven sensor needs to be replaced.
Good luck
Please rate FixYa!
GE ZSC2001FSS... • Answered on Sep 22, 2009
You may have to disassemble the door to get to it. Are you sure this is not a double paned glass and it is 2 pieces of glass in one assembly?
GE ZSC2001FSS... • Answered on Jan 30, 2009
contact GE; they should have replacement glass in stock.
GE ZSC2001FSS... • Answered on Jan 15, 2009
I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
GE ZSC2001FSS... • Answered on Aug 08, 2008
Check http://www.applianceaid.com/erange.html, maybe you can find some info to give an idea where to check.
If not power is circulating through it, I would suggest to check the fuses inside the appliance first. Make sure you disconnect it from the main power before attemping to remove and check the fuses.
GE ZSC2001FSS... • Answered on Feb 21, 2008
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
GE ZSC2001FSS... • Answered on Dec 26, 2007
GE code F97. We had power blips for several days, then tried to start the oven and got this code. Turned breaker off for a minute with no luck. Turned "clean" mode on for lower oven, and BINGO!!! The lower fan started up. Canceled clean mode. Ovens then worked OK with no error code!
GE Ovens • Answered on Apr 06, 2021
Sounds like you are missing a leg of power to the oven. The power is not correct. This unit needs 220V. You will have to check to make sure the power supply cord is connected correctly to the terminal block of the oven. Where the wires are connected to the oven block, you should have 120V from left to center, 120V from right to center and 220V from the two outer terminals. Right now it sounds like you only have 120V going to the oven. The display board operates with 120V so you will see the display but the elements need 220V to work properly. BE Careful, this is high voltage so call who ever installed it to check that power.
GE Ovens • Answered on Mar 28, 2021
A lot of electric fan ovens run the fan until the oven cools. This ventilated the cavity.
GE Ovens • Answered on Feb 28, 2021
GE ZSC2001FSS Advantium Electric Single Oven Logo
26 questions posted
Top GE Ovens Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
need user manual
  • Ovens
