20 Most Recent Marvin 2060 Compact Heater Questions & Answers
As you probably know by know Marvin is no longer in business. The original supplier of the electrical switches was tower mfg. They will not sell to distributers or supplies due to chance of legal matters, they will only sell to oem's. We have looked extensively and have found one supplier at present, if you find on please let us know. The switches we have purchased are 120VAC 13A and have exact mounting, one tab one screw with press in wire connectors. The only difference is this switches' stem is 5mm shorter. This means the bottom outside of the original control knob must be shaved 1/4" this will make for a perfect fit and will make this knob the same thickness as thermostat knob. This switch sells for $6.95 plus postage and comes with directions for modifications.
Marvin 2060... | Answered on Dec 31, 2014
Marvin replacement elements are available from Quartz Infrared for $17.95.
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Marvin 2060... | Answered on Dec 28, 2010
this can be purchase in any of the store that deal with electronic or kitchen aid around your local area .note :if you have fine it very difficult to get this part from any of the around you the you can order it from any of these below address
All any of these site order there customer a grater price and competitive service among other in the market,so feel free to go on shopping
www.maybenow.com ,www.23four.com/HouseHome/SpaceHeaters/WBMarvin2060/
Good luck,
Marvin 2060... | Answered on Dec 22, 2010
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Marvin 2060... | Answered on Feb 08, 2010
sounds like a bad wiring connection. you could take it to an electrician/small appliance repair shop and have it inspected. or just replace it. wouldn't use it as is though as this sounds like a high resistance connection and if so is a fire/shock hazard.
Marvin 2060... | Answered on Jan 22, 2010
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
Marvin 2060... | Answered on Jan 07, 2010
Marvin replacement elements are available from Quartz Infrared, Inc for $17.95. You can order them directly here:
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
One of the techniques I found to "re-energize" an Quatrz elelment is to Remove the cool element (unit unplugged, of course) and try to smooth the ends with sandpaper (220 grit) and then do the smae for the contacts. Replace element and see if it lights up.
Rmember NOT TO TOUCH quartz element with Bare Hands!!
Oil from skin can react with elelment and cause it to explode.
Marvin 2060... | Answered on Mar 27, 2009
Try going to www.onestopshopcatalog.com. I believe they actually have some in stock. I order some and we will see if I have any trouble.
Marvin 2060... | Answered on Feb 28, 2009
On Monday, 1/21/08, I returned the Marvin 2060 heater to the store I purchased in 02/07 since the freeze guard stop working. The owner left me a voice message at home and said he after doing some research, he discovered Marvin went out of business in 12/07.
And the heater is no longer covered under the warranty. The owner gave me a telephone number, 800.326.3690 which carry the parts for Marvin Heater. I have not called the number since I am looking for another heater with the freeze guard feature since it something I need quickly.
Do they have a fan in them. If they do then the noise maybe coming from a bent fan blade. If you are mecahanically inclined then I would go into it and see. That would be the only moving part in the thing other than the tip over thing inside. I hope this helps
Marvin 2060... | Answered on Feb 02, 2009
trw www.sears.com the parts dept...have make and model ready!
Marvin 2060... | Answered on Dec 11, 2008
try this place - they have replacement quartz elements maybe you can find one here.
http://www.infraredheaters.com/quartz.htm
Marvin 2060... | Answered on Apr 07, 2008
Is this one of those quartz type elements? If so I think you push it one way, forward or back to remove. Try a local appliance parts supply for the part.
Marvin 2060... | Answered on Feb 19, 2008
Marvin 2060 Compact Heater Logo
29 questions posted
Top Marvin Heating & Cooling Experts
Marvin
Marvin
Paul Carew
john h
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Marvin Heating & Cooling
Most Popular Question
rotary switch off 750 1500 bad marvin
  • Heating & Cooling
