20 Most Recent
Patton Electric Utility Heater, PUH680-WM1 Questions & Answers
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
- Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
- Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
- Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
- Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
Patton PQH307
Wires are rated to handle a certain amount of amps. Your dryer cord is bigger than your coffee maker cord because your dryer pulls more amps. What is going on with your heater is your heater is drawing more amps than the wire can handle. Therefore the wire is getting hot, melting the insulation. Hopefully it shorts out before it catches on fire!!! BOTH BAD SCENERIOS!!! It is possible your machine is just excessively dirty, therefore working extremely hard, drawing high amps. If you are able to give a good cleaning, do so. Let dry and turn heater on DURING A TIME WHEN YOU CAN MONITOR IT, NOT OVERNIGHT. See if it has made a significant improvement. If not, it's time for a new heater!! Best Wishes!! If you need further help, reach me via phone at
https://www.6ya.com/expert/thomas_092728000e6acb79
