20 Most Recent
GE Monogram ZE1660SA Microwave Oven Questions & Answers
Every time I open the
most likely the door latch assembly and or the door switch has failed... there are approx. 3 micro switches located where the door closes... these switches all operate items such as the cooling fan,timer, clock assembly etc... sounds like one of these micr switches have failed and will require getting inside to exam with a meter and check contuinity on close and open when switch is open...good luck to you...
Change Light Bulb Monogram zsc1001kss01
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
I've got a GE Advantium 120/Model ZCS1001KSS01, the display will get lines thru it, and comes in and out of view, and will always finish its cycle. however, when you go back to use, it is dead.
The problem with your Display of your GE Microwave/Speedcooker is not the Digitron WB27X10856 display board? The flickering and ultimately failure over of the display is due to the WB27X10861 GE microwave control board which is a rebranded (LG 6871W1A417/6871W1A417A board) which GE then sells as a markup. The princple purpose of this board is to convert (i.e. rectify) AC to DC at various voltage levels needed by the rest of the microwave to run their control circuits in the microwave. A portion of the GE microwave is always on so the AC/DC supplly is always on. Overtime the electrolytic capacitors in a section of the board fail or degrade to a point they the DC suppy starts to produce ripples in the DC power supply which results in circuit board failures. These ripples produce deep spikes of voltage of 120 Hz that the other circuits are sensitive too. I just exmined a failed WB27X10861 board and measued the capacitance of each of the seven electroylic capacitors. Of the 7 capacitors, 2 had failed over time. The others 5 have degraded 10 to 15 percent but still within their design spec. The two that failed, C07 - 1000uF 25 V had a measured value of 207uF and the other C08 - 220uF had a measured value of 13uF. There was no visible bloating on either SAMWHA SG capacitor. Nomally, these capacitors are rated at 2000 hour at 85 degree C. 2000 hr is only 83 days, but since the voltage is less and the temperature is probably 40 to 50 degrees inside the capacitor these capacitors may last 10 years. They harder they work the shorter the lifespan. There are two solutions, either purchase a new replacement control board or replace the failed C07 and C08 capacitors within the failed board with better ones. You can easily buy 10,000 hour , 105 degree C rated capacitors for probably 25 cents more than 2,000 hour capacitor. Most people don't have the resouces to repair a board so buying a new board is their only solution. Don't buy a used board on ebay because a used board is probably on the verge of failure.
