20 Most Recent
GE JES1855 Microwave Oven Questions & Answers
GE JES1855 1100 Watts Microwave Oven not working.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
The microwave does not heat
do you know basic electronics? or someone who does? if so get back to me and I will help, it is an easy fix.
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
I've got a GE Advantium 120/Model ZCS1001KSS01, the display will get lines thru it, and comes in and out of view, and will always finish its cycle. however, when you go back to use, it is dead.
The problem with your Display of your GE Microwave/Speedcooker is not the Digitron WB27X10856 display board? The flickering and ultimately failure over of the display is due to the WB27X10861 GE microwave control board which is a rebranded (LG 6871W1A417/6871W1A417A board) which GE then sells as a markup. The princple purpose of this board is to convert (i.e. rectify) AC to DC at various voltage levels needed by the rest of the microwave to run their control circuits in the microwave. A portion of the GE microwave is always on so the AC/DC supplly is always on. Overtime the electrolytic capacitors in a section of the board fail or degrade to a point they the DC suppy starts to produce ripples in the DC power supply which results in circuit board failures. These ripples produce deep spikes of voltage of 120 Hz that the other circuits are sensitive too. I just exmined a failed WB27X10861 board and measued the capacitance of each of the seven electroylic capacitors. Of the 7 capacitors, 2 had failed over time. The others 5 have degraded 10 to 15 percent but still within their design spec. The two that failed, C07 - 1000uF 25 V had a measured value of 207uF and the other C08 - 220uF had a measured value of 13uF. There was no visible bloating on either SAMWHA SG capacitor. Nomally, these capacitors are rated at 2000 hour at 85 degree C. 2000 hr is only 83 days, but since the voltage is less and the temperature is probably 40 to 50 degrees inside the capacitor these capacitors may last 10 years. They harder they work the shorter the lifespan. There are two solutions, either purchase a new replacement control board or replace the failed C07 and C08 capacitors within the failed board with better ones. You can easily buy 10,000 hour , 105 degree C rated capacitors for probably 25 cents more than 2,000 hour capacitor. Most people don't have the resouces to repair a board so buying a new board is their only solution. Don't buy a used board on ebay because a used board is probably on the verge of failure.
My GE space maker model JVM240BL001 the power is on the digital display reads Enter NORM SOUND 2
Hello, friend! It is noteworthy that if the GE Spacemaker microwave model JVM240BL001 is displaying "Enter NORM SOUND 2" on the digital display, it indicates that the microwave is in the programming mode for adjusting the sound level. To exit this mode and return to normal operation, you can try the following steps:
- Press the "Clear" or "Cancel" button. This should clear the programming mode and bring the microwave back to its normal state.
- If pressing the "Clear" or "Cancel" button doesn't work, you can try unplugging the microwave from the power outlet for about a minute. Then plug it back in and see if it resets the display.
- If the issue persists, consult the user manual for your specific model. The manual may provide additional instructions or troubleshooting steps to resolve the issue.
