20 Most Recent GE JVM1430 Microwave Oven Questions & Answers
GE JVM1430 Spacemaker is dead. Completely.
See my microwave oven safety file here. If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. How to test a high-voltage capacitor. If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. My door switch help file. If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse. If the fuse is easy to twist with your fingertips while it's in the holder, it's too loose. You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good. FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly. - William E. Miller, AS-EET [email protected] http://www.microwavecontrol.com Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
5/30/2017 12:31:14 AM • GE JVM1430... • Answered on May 30, 2017
I need to install my GE Spacemaker model #
You can download GE owner's manuals and installation instructions here.You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
6/6/2016 10:45:05 PM • GE JVM1430... • Answered on Jun 06, 2016
How many watts jvm1430bd002?
The GE JVM1430BD series of microwaves provide 950W of power. This information is in the Quick Specs for the microwave. The direct link to the document is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=340196_jvm1430bdwd_r2.pdf . (If the link changes, start here: http://www.geappliances.com/service_and_support/literature/ and search for your model. Three documents are currently available (Installation guide, Owner's Manual and Quick Specs) for the JVM1430BD series microwaves. I hope this helps. Cindy Wells
1/9/2015 12:03:17 AM • GE JVM1430... • Answered on Jan 09, 2015
0answers
manual
manual
I have had a service
google GE JVM1430BD002 and u should find many vendors that will sell it if it hasn't been discontinued
1/14/2011 4:40:09 AM • GE JVM1430... • Answered on Jan 14, 2011
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
11/4/2010 8:38:58 PM • GE JVM1430... • Answered on Nov 04, 2010
Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ew35
9/30/2010 2:01:57 PM • GE JVM1430... • Answered on Sep 30, 2010
Funny noise....zzzzzz........strong burned
heatman101
9/18/2010 2:46:32 PM • GE JVM1430... • Answered on Sep 18, 2010
GE Micro JVM1440, 4 years old. Was using, made
It may be as simple as a bad door switch or mount. See this file for help.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts (like the high voltage section) will require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
[email protected]
http://www.microwavedisplay.com
5/28/2010 1:25:49 PM • GE JVM1430... • Answered on May 28, 2010
Does not heat
Check the door safety interlock switches - if faulty, replace them.
2/14/2010 4:12:21 AM • GE JVM1430... • Answered on Feb 14, 2010
My son put a bag of chicken in it to reheat and
if you are handy you can pull off the cover and at least look for a fuse
1/17/2010 6:28:32 PM • GE JVM1430... • Answered on Jan 17, 2010
Where do I find the fuse on my ge microwave?
call a technaine for microwaves
10/9/2009 4:20:47 PM • GE JVM1430... • Answered on Oct 09, 2009
2answers
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
9/8/2009 5:31:29 AM • GE JVM1430... • Answered on Sep 08, 2009
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
8/28/2009 12:57:31 AM • GE JVM1430... • Answered on Aug 28, 2009
GE JVM1430 Microwave Oven Logo
32 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
  • Microwave Ovens
