20 Most Recent
Patton U2-1887HO Floor / Box Fan Questions & Answers
I have a 3 speed fan with a red, blue, black an
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
