20 Most Recent
Reliance 43614 Heater Questions & Answers
My siM is blocked nd asks PUK no pls help
A
request for a PUK code ("Personal Unlocking Key") will appear on your
phone if your SIM card PIN code is entered 3 consecutive times
incorrectly.
Your SIM card will then become
"PUKed" or Blocked. This is a security measure to protect your service.
You
need to call the Customer Service department of your cell phone
provider and they will give you the PUK code which will unblock your SIM
card.
How To Get My Puk Code Of 9098656025 Of Reliance
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
My water heater keeps making this knocking sound.
This sound is called "water hammer" yes it can hurt some pipes and valves in the house. It is caused by water pressure from the water co. being higher than normal, they have to raise pressure in areas to move water for new construction and what-not. The cure some times but not always is to install an "anti-hammer device on top of your hot water heater. a "water hammer arrester" is what they are called, cost about $11.oo and up. .
I need to replace the therocouple on my water
Most are replaceable, some aren't. If there is a nut holding it into the gas valve or electrical control, just unscrew it and put the new one in. Just get a universal thermocouple at a hardware store. They're usually less than $10. I keep a spare hanging between my water heater and furnace at all times.
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
