20 Most Recent
Rinnai Vent Free Gas Heater/: 10,000 BTU Vent Free Heater/ Questions & Answers
How do I turn of radiators for summer?
Step 1: Also known as a manual valve, find the non-thermostatic valve on the left or right side at the bottom of your radiator. The other valve on the radiator will be fixed or will be capped.
Step 2: To turn your radiator off, turn the valve clockwise as far as it will go.
I need an owner's manual for a Rinnai Glo-Ray furnace; model # REH-20FA-N
I would oil the fan spindle .There may be a oil cap you can do this from . The burner sounds like it needs a clean as it is not burniing blue . Lack of air . But it could be a heat exchanger problem. I would get someone to check this over . As they will know what to check for . Best I can tell you as A gas fitter I would say get it checked out .
Rinnai RC-329ac not coming ON although the power button is OK
It sounds like there might be an issue with the power button on your Rinnai RC-329ac heater. Based on your description, it appears that the power button is not functioning properly and the heater can only be turned on by using the "good night" button.
There could be a few reasons for this. One possibility is that the power button is physically damaged or malfunctioning and needs to be replaced. Another possibility is that there's a problem with the control board, which is responsible for managing the heater's functions.
To troubleshoot this issue, I would recommend checking the following:
- Check the power button to make sure it's not physically damaged or jammed.
- Check the control board for any visible damage or malfunction.
- Make sure the wiring connections are secure and not loose.
If you are not comfortable working on these issues, it's best to call for professional help as it may require a technician with experience in Rinnai RC-329ac to properly diagnose and fix the problem.
Error code 01
Error code 01 indicates a water flow sensor problem the sensor could be dirty or faulty also check the screen on the cold connection to the heater the heater may also be clogged with rust or scale and may be causing a low flow problem.cleaning the unit shuld fix this problem. Hope this helps
