20 Most Recent ICOM Informatique Icom Radio IC-F3, IC-F4, IC-T2A Compatible Battery Questions & Answers
did you check the manufactures web site
ebay is your friend
ICOM... | Answered on Feb 11, 2015
Yes. Both must be programmed to the same frequency and DPL code ( if digital) or TPL code ( if analog).
ICOM... | Answered on Jul 11, 2014
Hi, the problem is you only have 16 channels programmed in the radio. you can program the full 32 if you have- the software, http://hamradio.online.ru/ftp/dw.php?icf3f4.zip . And the programming lead- http://cgi.ebay.co.uk/USB-Interface-cable-for-ICOM-IC-v8-Radios-6-030_W0QQitemZ330356207021QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item4ceac3adad&_trksid=p3286.c0.m14
Hope this helps.
ICOM... | Answered on Sep 10, 2009
cqham.ru
ICOM... | Answered on Apr 13, 2008
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
ICOM... | Answered on Dec 30, 2016
Copied this from their manual:
The lock function prevents accidental frequency changes and accidental function activation. q Push (looks like f) , then push [7• ] to turn the lock function ON. •" " appears. (looks like f) To turn the function OFF, repeat step 2 above. •" " disappears.
http://www.icomamerica.com/en/products/avionics/handheld/a6/default.aspx
ICOM... | Answered on Sep 21, 2016
I really, really suspect your programming.
ICOM... | Answered on Feb 22, 2015
I thought it was the speaker
Radio Communications Logo
18 questions posted
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
normis101
Michel Laprise Sr
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • ICOM Informatique Radio Communications
Most Popular Question
icom ic f3 vhf programmable radio
  • Radio Communications
