20 Most Recent
Magix Movie Edit Pro 14 for PC Questions & Answers
Is movie edit pro 14
It should, because it worked on Windows Vista, which Windows 7 is based on. If it doesn't work, you can right-click on the desktop shortcut, and under the Compatibility tab, you can change it to Windows Vista SP2, which should let the program start.
When I try to install
this version was released with only 200/xp/vista support. you may just have to run both the installer and the software in compatibility mode. you can do this by right clicking the setup and on the top tab select compatibility mode then select windows xp sp3. there later version of this software (movie maker 17) does support the windows 7 platform
GL
Jammer
Serial Number
Hello
Unfortunately we are not permitted to provide serial numbers in
accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer.
The contact details should be on the side or back of the box or CD
cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
It keeps crashing when I try and import a video
In this age of High Difinition what you really need is a High End System. You need to upgrade your system. I would also recomend you to use a good Graphic Card while working with Video Editing. And if you heed to my words I would like to suggest you to go for an AMD Processor like the latest Phenom II with six cores and upto 32GB RAM capacity. To Go along with it a good level MSI/GIGABYTE/ZOTAC board and RAMs of 1600FSB(2X2 GB would be fine). Comparing it with i7 of Intel: it won't let you down. It would also be lighter on the pocket
Cant get video files to run from my media files.
You may be missing the codec to play them, if you google free video codecs and download the codec package for your operating system and install the pack it should cure the problem for you.
http://www.free-codecs.com/
try this link for various codec packs
Manual
can try the following links copy and paste in address bar.
en.kioskea.net/.../21454563-magix-entertainment-magix-movie-edit-pro-14-plus-crazy-talk-4-pc www.taringa.net/.../MAGIX-Movie-Edit-Pro-15-Plus-8_6_1_0.html - I’m happy to help further over the phone at
https://www.6ya.com/expert/walter_628d4d23d01fb34d
How do you upload a
You have to import the DVD, after you have click on the start page to create a new movie. In the workspace area, you will see the drives on your computer. Select the DVD drive and it should show the files on the DVD disc. Then import them into the work area. You can then drag the files to the timeline area.
