20 Most Recent
Apple Multimedia Software Acoustica Mixcraft 4 for PC Questions & Answers
When i play back my
try to play song on different music players like windows media player and if the studdering noise that you mention also occurs it means the problem is in your hardwares but if not and the noise only happens in mixcraft 4 then just re-install the software this should be able to fix the problem and if the noise is still there then you should go back to the store where you bought it and let them test it so that if the problem is in the cd you should be able to get a replacement
I was working on a
Hi 1. Open a cmd box. (Start > Run > cmd)
2. Open the Task Manager. (Right-click on the taskbar.)
3. Kill explorer.exe. Don't close the Task Manager.
4. Navigate in the cmd box to the undeletable file.
5. Delete it with DEL (I used DEL *.* for an immensely gratifying delete experience).
6. Using the File menu in Task Manager, restart explorer.exe. Also check this bellow link to delete 0KB files... http://www.automationanywhere.com/solutions/ST/T38.htm Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)
Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video.
To preserve the date and time information on your downloaded videos, you can try the following:
- Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
- Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
- Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
- Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
- Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
- Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey).
The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system.
If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app.
Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue.
You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue.
If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
Unlock MacBook pro
On the newer macs, you can hold down D while booting which will take you to diagnostics mode. There you can reset the password. For older systems, you will need boot media.
