20 Most Recent Goldstar Gold Star DH4010B 40 Pint Dehumidifier Questions & Answers
They are basically a refrigeration unit that draws the moist air from your home and condenses it on the evaporator coils. If you are getting no water, it could only be two things;
1. there is no moisture in your house.
2. the refrigerant gas is low.
Goldstar Gold... | Answered on Dec 29, 2015
The DH304Y5 dehumidifier is not subject to any recalls at this time.
I hope this helps.
Goldstar... | Answered on Sep 10, 2017
I can't hear YOUR dehumidifier and can't tell if it's out of the ordinary, but dehumidifiers have all the same internal parts as a refrigerator with the addition of a fan to blow air through the coils to keep them from freezing up. They do tend to be a bit noisy.
Goldstar... | Answered on Feb 22, 2015
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Goldstar... | Answered on Oct 23, 2014
unplug and wait a few minutes then reconnect to power to clear buttons not working , then ck filter to see that its not clogged use a flashlight to view inside to see if a heavy coating of dust exists iniside case , if so you might be able to save it if you unplug and remove case to access inside and clean out with vacuume hose coils are most important to get clean
ck your humidistat settings sometimes these get changed No one knows why ? 70%rh is considered normal
Goldstar... | Answered on Oct 22, 2014
If you know the model number, you might be able to find the manual here... http://www.manualslib.com/brand/goldstar/dehumidifier.html
Goldstar... | Answered on Jun 24, 2014
It sounds like the fan may not be operating or the air path is plugged up. I think what is happening is you are running the compressor on high head causing it the thermal relay to drop out.
Goldstar... | Answered on Jun 18, 2014
Goldstar Gold Star DH4010B 40 Pint Dehumidifier Logo
1 questions posted
Top Goldstar Dehumidifiers Experts
Tim Venetis
Tom Chichester
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Dehumidifiers
Most Popular Question
will no longer collect water fixable
  • Dehumidifiers
