20 Most Recent Frigidaire a/c fad704dwd 70 pint dehumidifier Questions & Answers
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Frigidaire a/c... | Answered on Sep 23, 2018
Good Afternoon Friend,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Frigidaire a/c... | Answered on Jul 03, 2014
i don't know. be careful with electricity. if possible, try running normal washer load along with your dryer but with [no heat] 'cold air only' to see if they will keep running.
if they run OK, consider shutting off both washer and dryer. shut off main electrical panel and change fuses for both washer and dryer. turn hydro on and run both again
with your normal settings. if they fail again please call for repairs. my dryer would not run and although everything looked and tested out OK, i had to replace a small 6x8"
electrical box having 2 only 30 amp screw in fuses.
then it ran OK.
Frigidaire... | Answered on Oct 02, 2019
if you fol;lowed all instructions and removed shipping braces then return for replacement or refund
Frigidaire... | Answered on Aug 25, 2019
Richard?
I have provided you a website that may help.
There has been a recall since 2013. Here below is the website.
My advice. Contact Gree. Be persistent and kind. Customer Support Reps, being people, can do wonders sometimes when they are treated kindly.
https://www.cpsc.gov/Recalls/2013/Gree-Recalls-12-Brands-of-Dehumidifiers/
Frigidaire... | Answered on Jun 16, 2019
Does it run after you get to the optimal humidity level?
If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
Frigidaire... | Answered on Feb 13, 2019
I understand you are looking for the owner's manual for your Frigidaire dehumidifier, model# FDL50S1. Attached is a link to your manual. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Frigidaire... | Answered on Dec 14, 2018
To remove the back cover, first remove the sides: two screws at bottom of side, one halfway up the back, one inside bucket opening. Also remove four screws holding the top on. Top slides forward to release, then sides slide up about 1/2 inch and pull straight out. Hooked into the front and back. Once the sides are off, the back will come off with remaining four screws.
Frigidaire... | Answered on Oct 19, 2018
First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Search-Results/?q=dehumidifier
*** The following is for information only ***
* Note that this filter is a "wash - Reuse" and is probably considered a "Part" and not a consumable.
* Filter (check if this will fit); https://www.amazon.com/Frigidaire-5304487154-Dehumidifier-Filter-Unit/dp/B00PU1V4M2/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1531339454&sr=1-1&keywords=frigidaire+fad704dwd+filter&dpID=61e1c6OA6UL&preST=_SX300_QL70_&dpSrc=srch
* Review; https://www.youtube.com/watch?v=BbwIEU3zlG8
* Correcting "Bucket Full" Error; https://www.youtube.com/watch?v=UzGnUG3r8dU
* Review (includes using a hose drain); https://www.youtube.com/watch?v=aAKN--TgQRI
* If your missing this filter then contact the local Frigidare or Appliance store for a replacement.
* Final; check your warranty. The filter may be covered.
Aloha, ukeboy57
Frigidaire... | Answered on Jul 12, 2018
Frigidaire a/c fad704dwd 70 pint dehumidifier Logo
2 questions posted
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
Steve
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dehumidifiers
Most Popular Question
will compressor our dehumidifier not
  • Dehumidifiers
