20 Most Recent Danby 60 Pint Energy Star Dehumidifier, Black DDR6011R Questions & Answers
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Danby... | Answered on Jun 26, 2020
try searching for " Danby dehumidifier model DDR070BBCBD8"
Danby... | Answered on Oct 28, 2019
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then
unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
Danby... | Answered on Oct 02, 2019
i don't know. my generic unit will do similar if i don't have the units moisture level set at a lower number. consider
using your lowest setting as a test.
Danby... | Answered on Oct 01, 2019
No, these are throw away items. It will cost more to repair than getting a new one.
Danby... | Answered on Sep 03, 2019
Call or contact Danby to request assistance.
Different model manual online:
https://www.danby.com/products/dehumidifiers/ddr050beccdb/
Danby... | Answered on May 01, 2019
Ck the fuse ,relay,freon psi wiring & compressor clutch
Danby... | Answered on Jan 07, 2019
Danby 60 Pint Energy Star Dehumidifier, Black DDR6011R Logo
3 questions posted
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
ADMIN Canada
ADMIN Canada
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Danby Dehumidifiers
  • Danby Dehumidifiers
Most Popular Question
danby dehumidifier ddr7009ree about 10
  • Dehumidifiers
