20 Most Recent Motorola Mobility MD761 Cordless Phone Questions & Answers
Are you getting a continuous busy signal, or just five or six quick beeps then a dial tone? If the latter, you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system. If the former, please add a comment to this question and specify the make and model of your phone.
Motorola... • Answered on Jan 26, 2015
Contact Cordless support. Looking For Help Mark motorola support
Motorola... • Answered on Jan 11, 2015
Hi Wilson.
If the phone displays out of range even when near to the base, try the following:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handset (or handsets) to cradle. I wrote at plural because the phone system may have more than one cradle/handset.
If that does not work, then the phone is defective.In that case you will need to replace/repair the faulty handset or the whole system.
If there is no reception, then the internal contact to antenna may be defective, either in cradle or handset (both have internal antenna). In that case contact Motorola support - Here Live Chat
Motorola... • Answered on Mar 12, 2011
Hello Carl,
This is a common problem for MD761. At random times the base station goes insane and all the handsets say "out of range" and stop working. The only thing that fixes it is unplugging the base station and taking out its batteries, putting it all back together (the battery compartment is poorly designed and the batteries don't want to stay in), and reprogramming the current date/time (which is also tedious). Then the handsets all work again.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Motorola... • Answered on Jan 10, 2011
You need to reset the time after a power outage.  Press the Day/Check, Hour, and Minute buttons until the correct time is heard-- Press Day/Check until you hear the correct day announced. Then do the same with Hour, and then Minute.
Motorola... • Answered on Oct 27, 2008
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Motorola... • Answered on Oct 15, 2008
Try unplugging all telephone (including the base unit), then try to call the number again. If there is still a busy signal, then the problem is with your telephone line/connection and you need to call your phone provider. On the other hand if the number rings, then chances are that base unit is defective (or one of your other phones physically connected to the tel line.).
To verify that it is the base unit or one of the other wired telephones,  reconnect them one by one and determine which of them will cause the busy signal. Problems like this can be caused by a power surge, near lightning strike or a simple component failure.
If it is the base unit, it is very likely an electronic problem and therefore would require familiarity with components and circuitry diagnosis, soldering and use of a DVM. Perhaps your best bet would be to seek the services of a qualified phone technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Motorola... • Answered on Jun 10, 2008
worked for us AFTER plugging/unplugging the base unit. thank you!
Motorola... • Answered on Apr 30, 2008
Open this link; go to the FAQ's for an MD760/MD761 and it solved my similar problem for my phone. Primarily, you will be resetting your system (almost like rebooting) and if necessary, deregister and follow with registering. I did not have to do the last part (deregister), but it does work. Good luck. http://broadband.motorola.com/consumers/support/default.asp?supportSection=CordlessPhones
Motorola... • Answered on Jan 23, 2008
Hi Tom
Can you please tell me what the model of the expansion phone. I may be able to research anf find you the correct procedure for resistering a new address number to the phone.
Thank you
Greg
Motorola... • Answered on Nov 07, 2007
on the handsets, use the menu until you find register. It's pretty easy from there.
Motorola... • Answered on Jan 28, 2007
Motorola Mobility MD761 Cordless Phone Logo
Popular Tags
27 questions posted
Top Motorola Mobility Lands Phones Experts
Harrie
Ngoro
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Lands Phones
Most Popular Question
rings but answer
  • Lands Phones
