20 Most Recent Lanier Cquence M3 Questions & Answers
There is no 64 bit driver available for this model. The only option is to find a smart media card reader that works on a 64 bit OS.
Lanier Cquence... | Answered on Jun 26, 2011
Have you tried the manufactuers web site? Let me know so I may provide you one.
Lanier Cquence... | Answered on Jan 12, 2011
IF you're scanning to folder, check your security settings in file sharing. Try allowing all permissions to each listed and apply.
If you there is a computer that you know definately works already, have a look at their settings in security tab of file sharing - and change permissions to allow full control (for now). See if your scanning works.
Lanier Cquence... | Answered on Feb 05, 2009
The m-3 is the same as the DS-3300 from olympus Check the ouympus usa web site for drivers and sw.
Lanier Cquence... | Answered on Jul 16, 2008
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Lanier Audio... | Answered on Dec 10, 2014
Some times the battery contact need to be pulled out a little bit. they are located down inside the battery compartment. You can stick a small screwdriver under the battery contact and bend it upward for better contact. If that doesn't work try removing the back cover and tightening the grounding screw, which is a silver screw located by the motor pulley hole. Sometimes this screw loosens up and then the ground is lost to the entire unit
It is under the flap located directly under the keyboard buttons. It is a slide switch and you can adjust it for a little recall or a lot of recall.
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Look under the front of the unit and there is a tel ans switch this must be on to enable the unit to answer the call
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
Lanier Audio... | Answered on Nov 07, 2013
Lanier Cquence M3 Logo
8 questions posted
Top Lanier Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Audio Players & Recorders
Most Popular Question
looking 64 bit
  • Audio Players & Recorders
