20 Most Recent
Samsung SyncMaster T240HD 24" TFT LCD Monitor Questions & Answers
How to mount samsung t26hd or remove the existing
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
10/20/2011 10:45:38 AM •
Samsung...
Answered
on Oct 20, 2011
I have a Samsung LN-T5265F
It is possible that the color processor is locked up and if you unplug the set from the wall for 40Min, it will reset back to normal.
2/6/2011 5:38:58 AM •
Samsung...
Answered
on Feb 06, 2011
Problem is that it sometimes goes into a freeze
go into your display settings and select the default settings first . If that solves your problem , then start changing the settings one time until your problem recurs . Then you'll know what not to set your monitor / video settings to .
5/12/2010 4:12:14 AM •
Samsung...
Answered
on May 12, 2010
Samsung t240 monitor lost pic
This problem with the T240 (t240M or T240 HD depending on the coutry) monitor on Windows 7 and maybe on Vista
is due to Samsung´s driver witch is not updated to Win 7. You will have to lower your video
resolution to 1600X1024 (higher resolution accepted) be able to use your monitor. Unfortunately it will not work on Full HD mode on Win 7,
until Samsung releases an updated driver for win7.
I had the exact same problem here and found this information together with the samsung people.
As yet they have no idea when the needed update will be available. Hope soon, till then no Full HD resolution for us.
Cheers from Brazil
4/15/2010 1:24:37 AM •
Samsung...
Answered
on Apr 15, 2010
I have 22
This could be your graphics card too , try plugg it into the onboard GFX , and see if it works, if not it is a fault with the screen unfortunatly , which you will then have to take back to shop .
Thanks
12/29/2009 10:35:56 PM •
Samsung...
Answered
on Dec 29, 2009
I have tried to hook up the monitor to the dvd
Most of the time its one of two things the cable needs to be replaced if you can plug into computer and it works that rules this out Second the connector on the dvd is bad this is the most occuring problem. I would try someone else's dvd player and see if it works.
12/7/2009 1:25:44 AM •
Samsung...
Answered
on Dec 07, 2009
It doesn't work with windows 7
it shuold work
check the machine resolution
right click on dektop
select setting
here you can change the resolution
10/31/2009 12:14:35 PM •
Samsung...
Answered
on Oct 31, 2009
