20 Most Recent Brother MFC-7340 All-In-One Laser Printer Questions & Answers
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
2/2/2022 8:24:31 PM • Brother MFC-7340... • Answered on Feb 02, 2022
Trying to scan and it says connecting to PC but nothing happens. It will print
Sounds like it is in the scanner software you re using. I would uninstall the software and printer, turn it off and remove the cables from the computer as well. Reboot the computer and the printer and reinstall the software. It will usually tell you when to attach the USB cable again.
11/14/2021 3:47:59 PM • Brother MFC-7340... • Answered on Nov 14, 2021
I need OCR software for mfc-7340 for windows 7 (64)
if you don't like to install ocr software to your computer, you can try this free online ocr tool
8/1/2021 7:20:19 AM • Brother MFC-7340... • Answered on Aug 01, 2021
I slided the coronora cleaner 5 to 6 times, but the drum error continues on my brother mfc 7340
same slide pcs on drum please contact printer vender
2/11/2021 6:52:48 PM • Brother MFC-7340... • Answered on Feb 11, 2021
Drum end soon Brother DCP-7030
each replacable part has its own life of rotation, heat conversion ect. may be the life cycle of the drum reached to end. you need to replace the drum assembly.
12/24/2018 9:10:41 AM • Brother MFC-7340... • Answered on Dec 24, 2018
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay. As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N. So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
9/25/2018 9:55:45 PM • Brother MFC-7340... • Answered on Sep 25, 2018
How do I install my MFC-7340's scanner to my PC?
Use the Brother **** that came with the printer or download the scanner drivers directly from Brother and then use "install new device" from computer control panel and point to downloaded drivers. Brother site has the manual too.
Here is the link:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7340_us_as
9/12/2017 11:31:28 AM • Brother MFC-7340... • Answered on Sep 12, 2017
0answers
2answers
I have an MFC-7340 - I did not get a disk and I
Click this:
http://www.massdrivers.com/dir/364907.html
1/20/2016 8:16:06 PM • Brother MFC-7340... • Answered on Jan 20, 2016
2answers
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
1/20/2016 8:15:33 PM • Brother MFC-7340... • Answered on Jan 20, 2016
2answers
My fax machine is Brother MFC-7340. How can I make
Hi daleneaquasu,
If you misplaced your manual you can download it for free, click this http://www.retrevo.com/support/Brother-MFC-7340-Multifunction-Printers-manual/id/23204bh633/t/2/.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
1/20/2016 8:15:09 PM • Brother MFC-7340... • Answered on Jan 20, 2016
2answers
How i load paper for brother mfc-7340
Here is the link where you can get the manua;l for that printer.
MFC-7340 Manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1/20/2016 8:13:29 PM • Brother MFC-7340... • Answered on Jan 20, 2016
How to remove the date and page number from printed sheets
If you are referring to a page number that is appearing on printed documents then you will have to look at the software you are using. If it is a premade document like an PDF file you would need a program capable of editing a PDF. If you are referring to the date and page number on a fax you likely cannot delete that.
6/5/2015 7:15:20 PM • Brother MFC-7340... • Answered on Jun 05, 2015
0answers
Brother MFC-7340 All-In-One Laser Printer Logo
410 questions posted
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
remove date page number from printed
  • Office Equipment & Supplies
