20 Most Recent
Samsung CLX-3175FW Multifunction Laser Color Printer Questions & Answers
My printer is 5 weeks old.
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
7/3/2016 10:44:38 PM •
Samsung...
Answered
on Jul 03, 2016
Invalid Toner Error
Dear Andy
the genuine cart. can solve the problem. also you can replace the toner chip with a fresh chip. as this chip kept the toner use and paper counts etc. so try it.
thanks.
3/31/2015 1:23:04 PM •
Samsung...
Answered
on Mar 31, 2015
How do I reset my samsung clx 3175 chip so that I
if you fill them your self, like i do, it will say "TONER EMPTY" then it will say STOP.
if you press the right arrow, it will say "CONTINUE" then press ok.
This way you should be able to print using the refilled cartiridges, but every time you open the fuser cover, or the printer gets turned on and off, it will ask you the same quiestion.
if you accidently press STOP, dont worry, just turn it off and turn it on again, and it will ask you it again.
Incase you need toenr powder, refill supermarket supply the powder, if you email them, they will give you a link to the requred toner powder.
it costs about £26 inc shipping uk, to refill the printer.
Hope this helps.
Jake
1/15/2015 4:49:58 PM •
Samsung...
Answered
on Jan 15, 2015
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
3/21/2014 5:35:16 PM •
Samsung...
Answered
on Mar 21, 2014
Samsung transfer belt color
First Take out the transfer belt out again and refix and put the connectors properly.Next check the driver settings.Check the toners are present and working by installing a samsung smart panel software.then u print .If the same thing exists. take assistance of service center. it may be HVPS problem.
3/5/2014 2:34:54 AM •
Samsung...
Answered
on Mar 05, 2014
