20 Most Recent Lanier VW-160T Questions & Answers
Press Telephone Record and Rewind together.
Lanier VW-160T | Answered on Feb 08, 2012
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Lanier VW-160T | Answered on Mar 20, 2011
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at www.tvps.com for large selection for professional Transcription units service and accessories http://www.tvps.com/Departments/Dictation-Accessories/Headsets/Cassette.aspx
Lanier VW-160T | Answered on Nov 25, 2010
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Lanier Audio... | Answered on Dec 10, 2014
Some times the battery contact need to be pulled out a little bit. they are located down inside the battery compartment. You can stick a small screwdriver under the battery contact and bend it upward for better contact. If that doesn't work try removing the back cover and tightening the grounding screw, which is a silver screw located by the motor pulley hole. Sometimes this screw loosens up and then the ground is lost to the entire unit
It is under the flap located directly under the keyboard buttons. It is a slide switch and you can adjust it for a little recall or a lot of recall.
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Look under the front of the unit and there is a tel ans switch this must be on to enable the unit to answer the call
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
Lanier Audio... | Answered on Nov 07, 2013
Itrizuto: Did you ever figure this out? I have the same question.
Lanier Audio... | Answered on Sep 07, 2011
Lanier VW-160T Logo
4 questions posted
Top Lanier Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Audio Players & Recorders
Most Popular Question
erase tape using dictating
  • Audio Players & Recorders
