20 Most Recent Lenovo ThinkPad X200 Notebook Questions & Answers
Try go into BIOS (press F1 after you start the pc). Then F9 for resetting BIOS settings.
Lenovo ThinkPad... | Answered on Sep 06, 2019
sounds like the driver you updated is causing it to shut down.try and start in safe mode and see if you can sort it from there.
Lenovo ThinkPad... | Answered on Oct 08, 2017
It might be on a power saving plan. You can change it if you want to but running it on battery while watching movies will drain the battery fast. Anyway, right-click the battery icon on lower right of the screen or search for power options. You can see what plans your laptop is saved to. Choose balanced or high performance or recommended settings.
Lenovo ThinkPad... | Answered on Jun 10, 2017
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Lenovo ThinkPad... | Answered on Sep 11, 2015
Try cyberlink youcam to take a good pictures plus with fun effects Free Trial YouCam 6 Deluxe
Lenovo ThinkPad... | Answered on Jun 17, 2015
If you have a password recovery disc that you have created then just stick that in your disc drive and it will be fine. However if you don't then all you can do is restart your computer or when you start it up keep pressing F8 (any computer). It will start the windows startup with the loading bar at the bottom and will then come up with A MENU. Select Repair My Computer. It will take you to another menu. Select the option which restores it to factory settings and wait. THIS WILL WIPE YOUR HARD DRIVE AND REINSTALL YOUR VERSION OF WINDOWS. NO INFORMATION IS RECOVERABLE. They are the 2 only ways. Good luck :)
Lenovo ThinkPad... | Answered on Oct 25, 2013
There are several reasons you would not be able to access Facebook. One reason would be that the site has been blocked via a proxy. The best solution in this case is to talk to the system admin. If that is not possible and you are trying to circumvent a proxy designed to prevent access from social media sites (IE: you are in school or work) then you should wait until you get home to access the sites.
Lenovo ThinkPad... | Answered on Oct 14, 2013
Anjan....
to reset the Bios password.. you have to take out the CMOS battery... It helps BIOS to remember the settings, password and date and time... you have to open the notebook backpanel... and then look for a small battery... take it out for a minute and plug it back...
i would suggest you to take the help of any laptop expert ...as by mistake you may do some damage to your notebook..
Lenovo ThinkPad... | Answered on Sep 09, 2013
install Nokia PC Suite
Lenovo ThinkPad... | Answered on Jun 04, 2013
There is a keyed lock on the right hand side to the rear of the base. Once this is unlocked, pull the release lever out and towards the front. The release lever is on the left side of the base towards the front. This will release the laptop from the base which one should then lift directly up to separate the two components.
Lenovo ThinkPad... | Answered on Apr 09, 2013
Power On password The Power on Password and hard drive password is used to protect the laptop/computer and hard disk from unauthorized access.
The hard drive password is setup in the BIOS you need the hard disk password to remove the password. I'm afraid you may have purchased a stolen laptop/computer. It is impossible to remove a hard drive's password there are no backdoor passwords because the password is stored in the hard drive's firmware. If the laptop/computer has a Power on Password then this laptop cannot boot up.
If the hard drive is password protected then remove the existing drive, replace it with a new hard drive may fix the laptop/computer r BUT it may also set a password on the new hard disk and lock it with the same password. If it does not password protect the new hard drive, then install Windows plus laptop/computer's device drivers and programs to get a working laptop/computer.
Lenovo ThinkPad... | Answered on Mar 17, 2013
This is an indication that your battery needs to be replaced. You can try http://www.pricewatch.com/
Lenovo ThinkPad... | Answered on Jan 22, 2013
A. right click on desktop > properties > Appearance and choose in the lowest entry large or extra large fonts
B. Change screen resolution desktop > properties > settings. Go to screen resolution
C. in a browser (i.e. IE) under view you can either choose "Zoom" (for everything) or "Text size" (only text)
Lenovo ThinkPad... | Answered on Nov 12, 2012
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Lenovo ThinkPad... | Answered on Nov 04, 2012
CHECK YOUR LAPTOP TIME N DATE FIRST.
Lenovo ThinkPad... | Answered on Oct 17, 2012
google translated
the problem of camera loump not seen it ALUME
it might be a driver or a bad / faulty lead connection depending on how the camera is connected and i dont know what an ALUME is
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
Lenovo ThinkPad... | Answered on Sep 15, 2012
Lenovo ThinkPad X200 Notebook Logo
63 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
use camera lenovo x200
  • Computers & Internet
