20 Most Recent Dell Inspiron 1721 Notebook Questions & Answers
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
Dell Inspiron... | Answered on Jun 28, 2014
yes this should work fine
Dell Inspiron... | Answered on Mar 02, 2014
what does the error say for me tobe able to help you
normally on a dell u have to have the power charger plugged in and hold the fn key bottom left and use the arrow keys to make it brighter. however it could be your screen or inverter that maybe faulty. the link below charges 60 pounds for inverter fix which contols the brightness and 100 pounds if it is the screen.
now for the bios password the only way you will be able to remove this is the strip the system down and remove the cmos battery for few mins with no power and put back this should reset it again the company can help you with this if needed. laptop repair london computer repair service no fix no fee
sounds like u need replace the screen on the laptop. i am based in london and have used the company below cost 100 pounds includes fitting and if it wasnt that which i would be very surprised they wouldnt charge you or search the screen up on ebay. hope this helps Help my laptop keyboard is broken
It seems the GPU is dying. It is cheaper to buy a laptop replacement than to fix this problem.
Hi Robert Harper,
It looks like an issue with Video (BIOS, Memory Shadowing)
Could you provide me with the Service Tag of the system?
You can try connecting external Monitor if available to check if that works? (After connecting external monitor you need to press fn+f8 to toggle the display)
Dell Inspiron... | Answered on Feb 21, 2014
Usually computers that have built in webcams come with a software suite for photos, unless Windows has been wiped an re-installed. I would check the Dell website with the service tag in order to see a list of programs/drivers that were installed when the computer was brand new. Let the site search your service tag for you. You should be able to download the programs needed right there.
Dell Inspiron... | Answered on Sep 19, 2013
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
Dell Inspiron... | Answered on May 10, 2013
Connecting an External Monitor or Data Projector
Toshiba = Fn + F5
there is a button on your laptop that will turn on your wireless. An led will come on and you will see a confirmation on the bottom right once it sees a wireless signal. the next part is to figure out if you have the security enable on your wireless router and if you do know what the SSID and the KEY for it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Dell Inspiron... | Answered on Feb 10, 2013
i don't know about dells set up But normally on the front panel there should be a slide swich to turn on the wireless connection if this fails contact dell
Dell Inspiron... | Answered on Feb 09, 2013
Try four zeros (0000) or password (password).
Dell Inspiron... | Answered on Jan 16, 2013
Do you mean the LCD screen with the lid?
If so you undo the hinges and disconnect the video and power leads to the inverter.
This WEB site shows how to remove the screen/hinges.
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Dell Inspiron... | Answered on Apr 28, 2012
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dell Inspiron... | Answered on Mar 25, 2012
Optical drive problems
NOTE: High-speed optical drive vibration is normal and may cause noise, which
does not indicate a defect in the drive or the media.
NOTE: Because of different regions worldwide and different disc formats, not all
DVD titles work in all DVD drives.
Problems writing to a CD-RW or DVD+/-RW
CLOSE OTHER PROGRAMS - CD-RW and DVD+/-RW drives must receive a
steady stream of data when writing. If the stream is interrupted, an error
occurs. Try closing all programs before you write to the drive.
refer to the manual , click this link http://support.dell.com/support/edocs/systems/ins1721/en/om_en/pdf/GU051A03MR.pdf
Dell Inspiron... | Answered on Mar 06, 2012
Dell Inspiron 1721 Notebook Logo
Popular Tags
70 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
screen doubled
  • Computers & Internet
