20 Most Recent Acer Extensa 5630-6806 Notebook Questions & Answers
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Acer Extensa... | Answered on Aug 18, 2019
Check RAM/ memory module and clean the connector with pencil eraser. To do that you have to open rear door using screwdriver. If it doesn't work, replace it with the good one that works.
Acer Extensa... | Answered on Jan 04, 2015
You can use windows password buster to reset the password.
See:
How to Reset Windows Password?
Acer Extensa... | Answered on Jan 13, 2014
check your audio manager and adjust your left right channels
Acer Extensa... | Answered on Sep 01, 2013
Firmly plug your ac adapter into the computer, gently move the plug from side to side, if it moves get the port checked.
Acer Extensa... | Answered on Apr 29, 2013
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Step 1:
Hey There,
Try googling Acer Extensa 5630ez drivers and then select the acer website.
Step 2:
You should now be able to select your Acer Model and will be directed to the Driver section.
Step 3:
Select the Network Drivers for your Model and download those.
Step 4:
After Downloading you simply have to install them and most probably Restart your Computer.
That should be all. Hope i could help.
Grs
Ben
Acer Extensa... | Answered on Dec 30, 2012
Please run system in safe-mode and see if it works then.
If both the keyboard and the touch-pad are not working, please remove the battery and run laptop on A/C.
If that doesn't help, reseat the keyboard cable on the mainboard.
If all fails, replace keyboard - It's a few US $
Acer Extensa... | Answered on Nov 27, 2012
You can install a new laptop keyboard.
Try this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Acer Extensa... | Answered on Nov 08, 2012
no free service guide !
what do u want to do i can guide u tell me
see these links for repair info very useful
http://www.laptoprepair101.com
http://www.laptopparts101.com
http://www.cyfinity.com/category/repairs/
pls rate me fixya if u got help
Acer Extensa... | Answered on Sep 14, 2012
Smartkey Windows Password Recovery Standard is easy to reset windows password, below are the detailed steps:
Step1: Quickly download, install and run this tool on an accessible computer.
Step2: Insert an empty and writable CD/DVD to the computer and start to burn it into a computer password reset disk with Windows Password Recovery Standard.
Step3: Insert the burned password reset disk to the target/locked computer, and set this PC boot from CD/DVD.
Step4: Reset forgotten computer password with the burned password reset disk in less than 1 minute.
Step5: After computer password resetting procedures finish, reboot your PC, and then you finally bypass your computer password and regain access to your PC.
Acer Extensa... | Answered on Jun 07, 2012
The laptop must be dismantled to access the motherboard, buy a can of compressed air attach straw. Now remove fan and the heatsink, blow out all open ports and fins on the heatsink and fan, next! remove thermal grease from the processor and heatsink with rubbing alcohol and a paper towel, now! apply fresh thermal grease to the processor and heatsink, "small thin layer evenly spread" now assemble, "solves most heat related issues"
Acer Extensa... | Answered on Apr 19, 2012
No display on either? Does it sound like the computer completed the boot cycle? Do you hear fans running and the hard drive spinning?
What happens when you hit the power button? Do you hear any beeps or see any blinking lights? Does anything post to the screen during the boot cycle?
If the boot cycle completed and you see no display on either monitor, then your video card is bad.
Acer Extensa... | Answered on Apr 12, 2012
Acer Extensa 5630-6806 Notebook Logo
Popular Tags
68 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
Extensa Acer
  • Extensa Acer
Most Popular Question
common acer5630 screen going blank hard
  • Computers & Internet
