20 Most Recent
Toshiba Satellite L355-S7902 Notebook Questions & Answers
No audio devices are installed
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7 Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable
2/13/2013 3:06:47 AM •
Toshiba...
Answered
on Feb 13, 2013
The dvd drive not work
Check in device manager to see if the computer can detect it or if it shows a yellow ! or ?
To get to device manager
- Right Click on Computer and click Properties
- Select Device Manager on the left, or in Win Xp click hardware tab and then device manager
If it doesn't show up at all I would say the drive is bad and needs to be replaced. Type your exact model number into ebay plus dvd drive and you should be able to find one cheap.
Let me know what you find out and if you need help replacing the drive, just comment back and I will walk you through it. Usually it will just be held on with one screen located on the back close to the DVD drive door but about 3-4" toward the middle.
9/20/2012 6:12:32 AM •
Toshiba...
Answered
on Sep 20, 2012
Cleaned a toshiba laptop and still shuts down
If you have cleaned/deleted some files and your laptop does not boot up then some important system files may have been deleted.You most likely need to install Windows again to get a working computer.
4/9/2012 9:48:22 AM •
Toshiba...
Answered
on Apr 09, 2012
Disk drive will not open?
Grab a small paper clip and then press the little hole with the tip of your paper clip. This little hole is found near the eject button of your disc drive, press it in and it will pop open.
2/8/2011 10:57:40 PM •
Toshiba...
Answered
on Feb 08, 2011
Can't get past password at startup how can i
http://download.imgburn.com/SetupImgBurn_2.5.2.0.e
xe
http://trinityhome.org/Home/index.php?
wpid=1&front_id=12
ON ANOTHER PC...
DOWNLOAD IMAGEBURN, THEN DOWNLOAD AND SAVE TRINITY
RESCUE CD ISO TO DESKTOP. BURN ISO IMAGE TO
CD/DVD. ENTER SETUP, CHANGE CD/DVD TO FIRST BOOT
DEVICE. PUT CD IN DRIVE SHUTDOWN REBOOT AND FOLLOW
INSTRUCTIONS TO RESET PASSWORD. BOTH SITES HAVE
EXCELLENT INSTRUCTIONS. ALL FREE
http://pcsupport.about.com/od/toolsofthetrade/ht/burnisofile.htm
^^^^ HOW TO BURN ISO IMAGE^^^^^^
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
10/27/2010 1:00:41 AM •
Toshiba...
Answered
on Oct 27, 2010
I have an L355-S7902. It will not power up. I
Hi
Thank you for your query
Have you checked the DC jack which usually comes of the motherboard (it is soldered on).
This is a key problem when it comes to laptops
Regards
Shauqat
9/29/2010 4:12:37 PM •
Toshiba...
Answered
on Sep 29, 2010
The cd rom keeps popping back out
What operating system do you have ?
Try reinstalling the Toshiba drivers that came with your computer. You need to have the original CD drivers for your Toshiba Satellite.
If you do not have these drivers, try downloading them from www.toshiba.com look for your specific model and have them ready before uninstalling the driver for the CD rom
8/25/2009 9:17:09 PM •
Toshiba...
Answered
on Aug 25, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
