20 Most Recent Motorola Mobility MOTORAZR VE20 Cell Phone Questions & Answers
You may try asoftech photo recovery which helped me before. You can download trial for free
http://www.asoftech.com/apr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Motorola... | Answered on Nov 20, 2013
Get a new phone
Motorola... | Answered on Jun 14, 2012
You'll need a USB-to-cell phone cable, commonly called a "tether." Normally tethers are
used to provide internet connectivity via cell phone to the computer (sounds desperate
and terribly slow, but not only is it possible, its better then nothing). Its also useful for
uploading pictures from camera phones to a PC/cloud.
The tether for your phone will have a USB type A port on one end (for the computer)
and a connector on the other end (for the cell phone) that's called a USB "Mini-B" connector (since you phone has a USB Mini-B port).
This cable is very commonly available, since its used for digital cameras (and nice MOTORAZRs).
Here's a link to one manufacturer's "USB Data Cable" for your phone:
http://www.wirelessgalaxy.com/motorola-rival-a455-oem-micro-usb-data-cable.html
I'm not endorsing www.wirelessgalaxy.com, its just that they have a nice photo of your tether.
Motorola... | Answered on Jun 09, 2011
The easy way is to use a mini SD card, copy your picture to that, then use an adaptor to use in your computer. You can send a pic. message to a friend who has the ability to then e-mail it to your computer. You can e-mail it to your self.
Motorola... | Answered on Nov 13, 2010
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Motorola... | Answered on Jul 23, 2010
ok the music kit had virtually no instruction and was tricky main thing is you cannot hook up the phone and cable to the computer first or together first thing run the disc or download the software from the link listed in the booklet then plug in your cable no phone and reboot to detect the plug and play device it will run its own drivers just hit yes to everything and let the wizard install it then plug in your phone and it will run its own separate drivers again hit yes let it run and then it will be able to sync when you press sync it will pull all of your music to a file remember this location write it down or you will be lost if you unhook it whille its transferring or want to use it later then drag and click the music from your media player over to the music kit software it will transfer it over for you its alot i know im sorry let meknow if you have trouble i was an alltel customer serivce rep for three years ill do my best by memory to help you out since I was recently laid off from verizon downsizing the alltel call centers
Motorola... | Answered on Jun 05, 2010
Here is the link for the Motorazr VE20 page at Motorola. You can click on the various user guides and also get the drivers and updates on the right hand side.
Motorola... | Answered on Mar 25, 2010
Then there is no problem with the phone if it can charge without the charger, but if you cant do anything when its charging, then I would try to give it to the company to fix it. Hope that helps.
Motorola... | Answered on Mar 22, 2010
the master reset code for a v3 is 000000 hopefully that helps
Motorola... | Answered on Mar 09, 2010
Try to run the files you got from your music player on to your desktop, see if that works. It simply looks like the files you had on your card are corrupted, maybe u need to delete these files and format you card, and then load music on it.
Hope this helps !!
Motorola... | Answered on Jan 26, 2010
DRIVER VE20 PARA WINDOWS VISTA
Motorola... | Answered on Jan 14, 2010
Motorola Mobility MOTORAZR VE20 Cell Phone Logo
43 questions posted
Top Motorola Mobility Cell Phones Experts
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
recover deleted photos in
  • Cell Phones
