ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Their are two ways this can be accomplished:
buying/ getting a code, then going through a process to unlock it
OR
Using a technique that does not involve codes OR money.
(I am NOT endorsing this product, nor do I have any sort of association with this product, I only recommend it)
If you so choose, you may use the code. This is actually the most popular, and instructions can be found here.
But for a second option, do this:
Or, for more options, just google "unlock nokia phones"
Hope this helped! Be Sure To Rate macapplezoo 100% Or Whatever You Thionk I Deserve!
Take both thumbs and place on back cover. Push away from the silver Xpress insert. Lift cover from back of phone. To put it back on, line up tabs and push cover toward the silver Xpress insert till it seats in place.
That could be the result of someone trying to jail break the phone.
The IMEI numer is a specific identification number for that specific phone and if changed will render the phone useless.
Question edited for clarity.
So the phone was likely stolen in Australia and shipped to Sri Lanka for sale. For the technician to unlock it by playing with the IMEI, it must have been PUK Locked AKA a SIM Lock. To remove a normal customer set PIN Lock, you just do a hard reset which scrubs the phone clean and reloads the operating system with no lock.
A PUK Lock can only be removed by the carrier that provided the phone. The technician tried the impossible task of removing an RSA 128 bit encryption lock by playing with the firmware and corrupted it.
You have three choices
1. Give it back to the technician and tell him to fix his mistake
2. Send it to Nokia to have the firmware and IMEI reinstalled
3. Throw it away.
Have a read of this Fixya Tip I wrote.
https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Never post IMEI numbers in an open forum like this. It is the unique number that identifies your phone from any other phone in the world. Those with malintent can clone a phone with your IMEI and you magically pay for their calls. This website gets 11 million views a year and the site has an excellent search feature!
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
You normally can't do that. The phone is locked to Tesco in the UK, you can only use their service provider in the UK. The long code is a PUK Lock / SIM Lock code and will lock you out when you put in another SIM Card. If you want to use it in Cyprus. you use a roaming package with Tesco. Or you buy a Cyprus phone.
https://www.fixya.com/support/r26056685-phone_asking_puk_code
