20 Most Recent Samsung SPH-m520 Cell Phone Questions & Answers
You may click the links below.
http://www.tradekey.com/selloffer_view/id/3270130.htm or call 1.800.SAMSUNG
Thanks.
Regards,
Neerak21
Samsung SPH-m520... | Answered on Sep 25, 2019
Start by removing the battery and the four small Phillips-head screws around the battery. Next, remove the plate on the back of the phone, below the battery panel. The panel is stuck in place with sticky foam and might be hard to peel off. Then remove the two small phillips-head screws. Next use a tiny (glass repair kit) flat-head screwdriver to pry the two halves of the base apart at the seam.
This is where it gets tricky. Gently take each piece off one-by-one. But to separate the screen you have to slide it half way and hold it in place while you unplug the ribbon cable from the circuit board in the base of the phone. Then disconnect the arm from the slider and slide the phone open to remove the two screws behind the silver stickers on either side of the camera "shutter". Now pry the slider housing apart as with the base.
Samsung SPH-m520... | Answered on Aug 04, 2013
Hi
The flex that connect the screen and the screen is damage.
You should replace the flex cable that connects the screen from the main board.
Till will not cost up to $10.
Thanks
Samsung SPH-m520... | Answered on Jun 23, 2013
this is not possible because the screen is blind. When you connect the phone to PC, you need to accept/press something on the phone to connect to the PC. Now the screen is white, you can't see what button you are to press on the phone.
I would suggest you replace the screen. Also, if your phone uses sim card, you can remove it from your phone and insert it into another phone. You might be lucky to find your contacts on the Sim.
Now to fix the problem, read further:
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Regards.
Walesarumi
Samsung SPH-m520... | Answered on Sep 28, 2011
QUESTION:::::::::: I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I\'ve tried each of the options, resolutions, brightness controls, etc. Sometimes (not every time) after I make a change to the brightness or resolution or white balance setting the picture goes back to normal - but not everytime. Most of the time it\'s just unusable because it\'s so distorted... almost like it\'s over exposed? I\'ve literally checked every setting available to no avail. I want to say it started happening after doing a firmware upgrade. Anyone else having that problem?
answer: i never knew the answer in exam also i cheated fron s 10's boy, the invigilator scolded me but i drank dew ans said daar kay aagey jit hay and continued my cheating program.
so u also cheat the solution of ur desk partener OR buy NOKIA 1100 its perfect 4u ********!!
Samsung SPH-m520... | Answered on Nov 11, 2010
the truth is that you can unlock the phone ,but you can't unlock all phone for free.
The payment sites are very cheap you could try it out and see.
You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
Samsung SPH-m520... | Answered on Aug 21, 2010
Visit the link below if you are interested in buying the unlock code:
Good luck.
Samsung SPH-m520... | Answered on Aug 04, 2010
hi :) screen distorted ?? for slide phone,the screen and inner upper keypad was control by a ribbon. if the ribbon spoil,will effect screen,upper keypad cant use,coming speaker cant hear. what u need to do better send for technician replace a new ribbon.
if my solution useful,please rank me.thank.
Samsung SPH-m520... | Answered on Jul 19, 2010
ur display has gone..... service it in samsung service station
Samsung SPH-m520... | Answered on Apr 11, 2010
Those slide up Samsung phones have always done the same thing to me.
Close it and let it go dark and then slide it up and/or turn it off and back(at least thats how i use to solve the problem.) on its just Samsung because I have had several and i swear they have all done the same exact thing!!!
Samsung SPH-m520... | Answered on Mar 03, 2010
Slide It Up
Samsung SPH-m520... | Answered on Feb 01, 2010
http://www.fixya.com/support/r3771170-phone_water_damage
Samsung SPH-m520... | Answered on Jan 08, 2010
Samsung SPH-m520 Cell Phone Logo
61 questions posted
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SPH Samsung
  • SPH Samsung
Most Popular Question
screen dispay all white fixed
  • Cell Phones
