20 Most Recent LG FLATRON L1919S-SF 19 inch LCD Monitor Questions & Answers
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
LG FLATRON... | Answered on Dec 05, 2013
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194W&kategoria=monitor&kat2=all
After removing all the screws and the base, I use thin flat blade screw driver to crack open the case starting at the bottom egde and work your way around, just watch out for any cables attached to the front bezel. The monitor is not made to be easily open up.
Please read my guide so you will know what to look for inside the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
LG FLATRON... | Answered on Jul 13, 2012
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
LG FLATRON... | Answered on Jun 11, 2011
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
LG Flatron... | Answered on Feb 10, 2018
It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
LG Flatron... | Answered on Nov 12, 2017
Flatron l17175
what on earth is that?
ahhhhhh and LG, lucky Goldstart monitors. not HP.
wrong forum Ill move you.
LG Flatron... | Answered on Oct 16, 2017
Sounds like it has a CRT and the EHT is collapsing. Maybe a dry joint around the timebase output transformer.
LG Flatron... | Answered on Mar 18, 2017
You need to use a ESR meter to check capacitors
LG Flatron... | Answered on Mar 02, 2017
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
LG Flatron... | Answered on Aug 22, 2016
Settings.... Wireless
LG Flatron... | Answered on Jun 23, 2016
are you in dual screen mode on a laptop possibly? Check that the laptop is dual enabled so that it is either an extension or a duplication of your main screen. This is common mistake in setting up external monitor on laptop.
LG Flatron... | Answered on Apr 10, 2015
LG FLATRON L1919S-SF  19 inch LCD Monitor Logo
7 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
lg flatron l1919s not powering hapend
  • Computers & Internet
