20 Most Recent Pitney Bowes C180 Copier Questions & Answers
I have this manual on my computer. If you send an email to [email protected] I will send the manual to you right away. Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Pitney Bowes... | Answered on Oct 22, 2011
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Pitney Bowes... | Answered on Dec 31, 2010
the sorter bins are binding when they try to move. check for alignment
Pitney Bowes... | Answered on Oct 05, 2010
Error 26 is referred the explorer can be in favor heavy of dirt, which causes that it does not have the suitable speed of return. Clean and you lubricate the zones of work of the to explorer.
Pitney Bowes... | Answered on Mar 18, 2010
This machine doesn't really print out reports. The copy counter is inside the front door.
Pitney Bowes... | Answered on Feb 24, 2010
check that the toner bottle is in coreectly. remove the toner bottle and close the door. wait for the motor to stop turning (3 minutes) insert toner bottle with hole facing up.
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
There is a sensor by the drum that checks the image on the drum. If the sensor is dirty, or the image on the drum is too dark, it causes this code. 18002435556 for service.
The drum or the cleaning unit has gotten too worn. call 18002435556
The e7 code is for the sorter problem. you can either call for service 18002435556 or just remove the sorter and use the copier without it.
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
40 questions posted
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Pitney Bowes Office Equipment & Supplies
Most Popular Question
c180 says e2 printer tray light blinks
  • Office Equipment & Supplies
