20 Most Recent eMachines E19T5W 19" Monitor Questions & Answers
Chances are the power supply in the monitor is going out.
Today, monitors are cheap and unless you have a 24' or better, it really doesn't pay. You may spent $100.00 and find one new for $135.00
Hope this helps
eMachines E19T5W... | Answered on Mar 22, 2014
Native resolution is 1440 X 900
eMachines E19T5W... | Answered on Mar 01, 2012
Do you still have the monitor? Would you consider selling?
Thank You, Lcdman
eMachines E19T5W... | Answered on Jun 12, 2011
I think this is due to the panel of your moniter this can be fixedby giving this mobile for service
eMachines E19T5W... | Answered on Dec 05, 2010
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
eMachines E19T5W... | Answered on Aug 20, 2010
This is most likely a backlight related problem. It is most likely one of two problems:
1) Something is wrong with your power/inverter board. Most likely you will need to replace bulging or bad capacitors on the power board. They will like have voltages between 16-25V and capacitances of 470-1000uF. You will need to disassemble the monitor, remove its power board, and inspect it. If you notice bad capacitors, you will need to desolder them from the board and solder on new compatible ones. This should solve the problem.
OR
2) If replacing the capacitors doesn't solve the problem, the problem may be with your backlights themselves. If you are able to test them, that would be best. Replacing them is a pain as you will have to disassemble the LCD panel itself to get them out. You will then have to replace them with compatible backlights of the same size, which you can salvage from similarly sized broken monitors.
Keep in mind that the suggested actions above are for individuals with some experiences in soldering and repairing circuit boards or LCDs. Also be sure to wear anti-static gloves or wristband and keep the monitor unplugged when performing the above stated actions (except of course when testing voltages).
Please check this link for the user guide of emachines monitors and check the troubleshoot section..hope it will help….
http://downloads.emachines.com/userguides/8513185_FlatPanelMonitor_UserGuide.pdf
Let us know if you want something more else accept the suggestion.
Thank You for contacting Fixya.com
eMachines E19T5W... | Answered on Jun 18, 2010
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
eMachines E19T5W... | Answered on Jun 16, 2010
Is the monitor still under warranty? (probably only the first 12 months)
Try connecting the monitor to a different desktop/notebook computer, to see if it is fine.
If it is, you have a problem with the video-card in your computer, not a problem with your monitor.
There are "capacitors" inside the monitor, that serve to supply "smooth" and "ripple-free" power to the electronic circuits. If you have "bad" capacitors, they are not doing what they should be doing, which causes the electronics to malfunction.
So, if your monitor is a CRT monitor, it's time to responsibly recycle it, and buy a new one.
If your monitor is an LCD monitor, take it to any TV/video repair shop, and pay them $25 to $50 to "inspect" it, looking for "bad caps". Or, spend that $25 to $50 to buy a new LCD monitor.
eMachines E19T5W... | Answered on May 31, 2010
eMachines are well known for having VERY POOR quality products. If it's turning on and off all the time, it really has to be defective, sorry. check www.mwave.com for great discounts on monitors, I buy from them all the time. Erick
eMachines E19T5W... | Answered on Dec 20, 2009
first try using a different connector.......or a different monitor and see if u have the same problem with it...............if it gives you the same problem u can try downloading the monitor driver to a cd (when u can get it to come on).....then re install the driver............ if this doesnt work it may be a faulty monitor card in the back of your computer that needs to be replaced.
eMachines E19T5W... | Answered on Apr 08, 2009
Thank you for your time but i did fix the problem! all i did was down load a new set of Driver's an it took care of the problem Ty again !
eMachines E19T5W... | Answered on Mar 23, 2009
Make sure your installing the right windows either 32 or 64 bit windows.you can't install a 64 bit system on a 32 bit if it doesn't support it.
eMachines... | Answered on Oct 26, 2019
microsoft has a license type called OEM which detects the computer that it is installed on and some computers have the licence key stored in the bios of the computer.
So when you grab the old hard drive and put it in the next computer Windows will detect you changed computers and not run as per OEM licensing rules that it runs on only the original purchased computer.
You might be able to run the drive as a secondary drive but you would need to install a new windows operating system and hard drive. And then use a partioning program to make the secondary drive not an active drive.
also you new machine most likely has a different type of bios called EFI
and you would have to change its settings to run AMI Bios but I do not think that is your problem as I think it is OEM but it might be worth investigating if you can run a legacy bios in the bios settings.
eMachines... | Answered on Oct 05, 2019
Hi there. If your desktop has been overheating for any reason you will need to look at buying a new processor (cpu), power supply (if wires have been damaged from heat or voltage spike), or possibly a new motherboard. It would be advisable to have a computer shop look at the internal components of your desktop. Heat or a surge in power can damage the computer hardware. Good luck!
eMachines... | Answered on Apr 09, 2019
eMachines E19T5W 19" Monitor Logo
29 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
e19t5w monitor doesnt stay once power
  • Computers & Internet
