20 Most Recent
Hyundai Electronics L19T+ LCD-TV 19" Monitor Questions & Answers
Installation problem
did you give them the right address because you are not on the right page here for these comments
This fixya site and you got nothing and there is no service from this site
11/11/2017 8:46:41 AM •
Hyundai...
Answered
on Nov 11, 2017
TheLCD is not working on resulution 1024x768 do i
Yes, it is very possibility of driver problem, but you can check it to attached with another PC. If the problem will persist you need to drivers. And another possibility is the LCD did not support 1024x768 resolution.
Good Luck
3/4/2011 10:40:34 AM •
Hyundai...
Answered
on Mar 04, 2011
The LCD screen lights up
Good luck. If it has failed, some times LCDs can be brought back to life refluxing the solder with a heat gun.
3/3/2011 10:47:03 AM •
Hyundai...
Answered
on Mar 03, 2011
Hyundai L19T lcd monitor.
Monitor powers
Sounds like you have some bad electrolytic capacitors.
If you are
tech savvy, open up the unit and look for capacitors that have bulging
tops or leaking electrolyte / bulging at the bottom and replace any/all
that look like this.
In most cases, this will fix you right up quick.
It's the right age for this to be the most likely issue.
The capacitors will be near the power input and the inverter stages of the circuitry.
2/22/2011 6:57:16 AM •
Hyundai...
Answered
on Feb 22, 2011
MONITOR SHUTS DOWN : WILL
purchasin757, What type monitor? If lcd type, may have 1 cold solder joint of some component lead on the "switch-mode-power-supply / inverter ballast circuit board, that goes "open" (intermittant) after it reaches a certain unspecified temperature/time period. Unit will need to be investigated by you or electronics technician to find common problem related to all brands of CCFL back-lit LCD monitors. How old did yu say your unit is??? May be that it also need some new electrolytic filter capacitors to be installed on the SMPS/ inverter board to make it servicable for 2 to 4 more years. Lots of video clips you should investigate at YOUTUBE before you return to fixya to do a customer reply and rating of this response to your post. You will also want to do a lot of readng in the fixya profiles of "budmrtn" "12fixlouie" for more info on this (your "black screen of death" symptom) common problem that affects not hundreds, but many thousands of lcd monitors. Let us know what you will do, after you research problem. 12fixlouie
11/2/2010 2:55:48 PM •
Hyundai...
Answered
on Nov 02, 2010
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
