20 Most Recent
Dell 22" SP2208WFP Widescreen Flat Panel Monitor Questions & Answers
Dell monitor blue light on no display
Hook it up to a different computer or laptop. If it still has issues then change out the cable. Add more info: has it ever worked? When was the last time it worked.
4/16/2014 12:43:33 AM •
Dell 22"...
Answered
on Apr 16, 2014
Pc monitor will not come out of hibernation
This may work for you it did for my son, Open control panel go to power options. set your pc to home/ office or what ever you use it for even always on if you like. Also at the top there is a hibernation icon open it make sure it is unchecked. You can also find the download for your monitor and see if there are any updates get them. and open up the file update,it there are any. some have an option for all kinds of settings display and such. Good luck
10/12/2012 2:07:03 PM •
Dell 22"...
Answered
on Oct 12, 2012
Vertical lines (about 1 cm
It's going bad. Contact the manufacturer to see if it's still under warranty, you may need the receipt if it is under warranty.
3/28/2011 4:08:10 AM •
Dell 22"...
Answered
on Mar 28, 2011
How can I disable my monitor's sleep mode? I
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
12/23/2010 5:16:58 PM •
Dell 22"...
Answered
on Dec 23, 2010
Dell 22" monitor goes black
Your monitor probably has bad capacitors now. Bring it to a local electronic repair shop and have the monitor tested. They can easily replace any bad capacitors.
I hope this helps. Have a nice day.
- HotRatchet
12/14/2009 11:41:26 PM •
Dell 22"...
Answered
on Dec 14, 2009
SP2208wfp monitor goes into sleep during videos
Assuming you are using Win-XP, go into control panel, Appearance and Themes and Choose a screensaver. There should be an option below the screensaver choice to adjust Power Saver settings.
9/19/2009 10:53:27 PM •
Dell 22"...
Answered
on Sep 19, 2009
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
