20 Most Recent Samsung 6345 Copier SCX6345 Printer Questions & Answers
3answers
Whats the admin password for scx 6545n
The initial administrator's setting is as follows: • The default ID: admin • The default password: sec00000
11/6/2021 3:44:39 PM • Samsung 6345... • Answered on Nov 06, 2021
Job cannot be accepted becouse scanner recousce is preoccupied
First I would cancel all accumulated copies, then disconnect the printer from the outlet and then restart. You may have to do this a couple of time, Good luck!!
9/17/2016 3:17:40 AM • Samsung 6345... • Answered on Sep 17, 2016
Reset password 6545n
try this to reset admin password Press "1, 2, 3" at the same time, Password for diagnostic men? is "1934", now go to "Test Routines" and select "Other" on the left men?. Now you can see "Admin Password Reset" botton, use it and reboot the machine Now you can use Default Password (1111)
3/10/2016 1:43:02 PM • Samsung 6345... • Answered on Mar 10, 2016
0answers
What do I do?
Be the first to answer 5/28/2014 3:24:49 AM • Samsung 6345... • Posted on May 28, 2014Be the first to answer
0answers
Password samsung 6345N
ok for this on user put the user name1)if it doesnt have a password font leave blank type in capital letters NONE and itll work its a glitch
4/10/2013 6:45:23 PM • Samsung 6345... • Answered on Apr 10, 2013
0answers
2answers
Printer says to install staple cartridge when the
The problem could be possibly due 2-3 reason
A) the plastic locking tab is not closed properly while you inserted the new staple cartridge
B)The staple cartrdge is not fitted properly
C)The Used staple cartridge was not replace properly
To solve this
Remove the cartridge and re-insert it while making sure that after fitting it you lock the lockin tab
Tun off the printer and re-start it
Hope this would help...if not please reply...we can perform further troubleshooting
9/13/2010 4:06:57 PM • Samsung 6345... • Answered on Sep 13, 2010
Samsung 6345n keeps jamming @ registration
replace the sensor above fuser.
5/23/2010 12:02:44 PM • Samsung 6345... • Answered on May 23, 2010
Samsung scx-6345 shows paper jam in document
CLEAR THE MEMORY. OR YOU NEED TO CHNAGE THE FUSER
3/16/2010 11:47:51 AM • Samsung 6345... • Answered on Mar 16, 2010
Samsung scx-6345 21.006 tray lift error
Try changing the SMPS.
3/16/2010 11:47:02 AM • Samsung 6345... • Answered on Mar 16, 2010
The samsung 6435n will not recongnise tray 2 and
please check on the settings of the manual. maybe someone must have mis-config it.
3/5/2010 5:10:36 AM • Samsung 6345... • Answered on Mar 05, 2010
How to you adjust the scan motor and tension belt
just adjust the software in the computer because it is installed in the pc .
3/3/2010 7:12:42 PM • Samsung 6345... • Answered on Mar 03, 2010
Samsung 6345 Copier SCX6345 Printer Logo
27 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
whats admin password scx 6545n
  • Office Equipment & Supplies
