20 Most Recent Lexmark C540N PROD SPECS TBD Printer Questions & Answers
942.02 Service Yellow TMC Sensor
Remove the toner cartridge, and inspect the lenses on the toner meter cycle (TMC) card.It is positioned on the right side of the toner cartridges
Are the lenses blocked, or dirty? Clean them
If damaged replace them
7/31/2021 7:17:48 AM • Lexmark C540N... • Answered on Jul 31, 2021
2answers
Where do you find the waste toner box on the
Open up the right front cover, open up the right upper cover, open up the right lower cover. the waste toner cartridge is there facing you, it should just pull out.
Part number C540x75G
One on ebay uk Item number 180577646764
7/31/2021 7:17:36 AM • Lexmark C540N... • Answered on Jul 31, 2021
3answers
Lexmark 540n 976:0 service network software
Had the same probelm. Resolved it by disabling AutoIP feature in Network Settings. Also set hard IP without DHCP.
8/15/2017 11:04:30 AM • Lexmark C540N... • Answered on Aug 15, 2017
I need the software to install it at my new laptop and i don't have the disc.
You can download the drivers online: http://bit.ly/N1Pt31. Just choose the Operating System of your computer.
10/21/2013 2:09:14 AM • Lexmark C540N... • Answered on Oct 21, 2013
0answers
Lexmark c540n creasing paper
First, check the quality of the paper you are using. The fuser will heat the paper, it tends to give a wrinkled effect on the paper. Try a new ream of good quality paper, and if it still does the same, the fuser itself might be causing the issue and you might need to replace it. For further details, please contact our Technical Support Hotline on 1-800-539-6275.
11/28/2012 11:00:12 PM • Lexmark C540N... • Answered on Nov 28, 2012
HOW TO GET SOFTWARE FOR FREE
You can download the software here: http://bit.ly/N1Pt31Just choose the operating system of your computer.
8/30/2012 7:29:03 PM • Lexmark C540N... • Answered on Aug 30, 2012
Lexmark printer is printing pages out with three black smudges on left margins
Best bet is to remove the cartriges, open all areas of the printer you can, remove the fuser. Then take a can of air and blow everything out. Reasemble the printer and run a few test pages. The smudges may be worse at first but should clear up. If this does not work, then try replacing the cartridges with a spare if you have one. If you find that it is a certain cartridge that is causing the issue, then you have a bad one. If it makes no difference at all, try to replace the fuser.
2/22/2012 6:02:44 PM • Lexmark C540N... • Answered on Feb 22, 2012
0answers
I HAVE A FUSER ERROR 122.06,122.05 AND 122.06 ON A
A 122.05 or 122.06 Fuser error indicates that the printer/MFP has detected a problem with the fuser unit. A service call will probably be required to solve this issue. However, certain rare occurrences, such as a power fluctuation or a static discharge in the vicinity of the printer/MFP, can cause a false 122.05 or 122.06 error message to appear. In such cases, the error is only temporary and can be easily resolved without service.
Try perform the following steps:
  • Power off the printer/MFP, wait 30 seconds, and then power it on again.
Did the error message return?
  • If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector, extension cord or uninterruptible power supply (UPS), can generate false error messages. Verify also if the printer works on a 110 or 220 volts source. Make sure that the power outlet matches its working voltage rating.
If this doesn't resolve the error, I suggest you contact Lexmark Technical Support.
10/20/2011 5:46:55 PM • Lexmark C540N... • Answered on Oct 20, 2011
88 replace cyan cartidge in Lexmark
You need to change the Number 88 Cyan Cartridge on the Printer!!!!
9/17/2011 2:40:08 PM • Lexmark C540N... • Answered on Sep 17, 2011
How i can delete a job?
On bottom right, in system tray icons open the "printing jobs", select the job and click on "stop", "remove" or "cancel" button as provided by your operating system
7/22/2011 7:52:50 AM • Lexmark C540N... • Answered on Jul 22, 2011
Lexmark C540N PROD SPECS TBD Printer Logo
68 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
lexmark printer says waste
  • Office Equipment & Supplies
