20 Most Recent
Motorola Talkabout T289 (14 Channels) 2-Way Radio Questions & Answers
[email protected]
Height and placement of your antenna determines range. In normal circumstances a two-way radio will talke line-of sight up to 2 miles. Any obstacles you have inbetween the two radios will shorten the range. Talking from inside to outside you can expect only 1/4 to 1/2 mi. range. Hold your antenna perpendicular to the ground (straight up) for the best range. Tilting the radio to the side can reduce range by up to 2/3s. (You'll need to do the conversion to kilometres).
Best regards.
5/22/2013 10:06:10 PM •
Motorola...
Answered
on May 22, 2013
T289 battery replacement. Does
No, but it might be handy to remove it. To remove it you would look at the front of the radio, and place a small screwdriver under the lip of the clip and gently pry up. However, you can remove the u-shaped bottom without removing the clip.
best regards.
2/2/2011 4:42:52 PM •
Motorola...
Answered
on Feb 02, 2011
Wondering about a charger
The "alkaline" version of your radio uses thee "AA" batteries and is not equipped for using a charger. Don't panic though, just visit any store with an electronics department. You can pick up NiMH rechargeable batteries and a generic charger. You have to remove the batteries from the radio to charge them, but you can always keep an extra set of batteries charged and ready for use.
7/26/2010 6:30:42 PM •
Motorola...
Answered
on Jul 26, 2010
How to turn off motorola T289 two way radio
On your left hand side as you face the radio, there is a row of buttons. The top button is the power button.
Here is a link you can copy and paste for the owners manual. (Click T289 PDF in the upper right hand side of the page to download)
http://www.usersmanualguide.com/motorola/2-way_radio/t289
1/27/2010 4:38:05 PM •
Motorola...
Answered
on Jan 27, 2010
I need help to dismantle a motorola radius sp10 2 way radio
Remove the battery, slip a small screw driver into the slot at the bottom of the radio between the outer housing and the battery tray, gently pry up. If your radio has a pair of battery contacts on the exterior they will come up with the tray. Be gentle, and do not disturb the Mylar ribbon that runs down the back of the tray. Once the tray is removed, using a frame removal tool (shaped like a squared letter U) you slip the tool in the channels on either side of the radio where you removed the battery tray. Then slide the tool upward until it meets the two plastic ears. The tool will slip under the ears and using your tool you can push the component board out the top of the housing. If your radio has an 8-dip-switch private line board, you may want to watch you do not damage or dislodge it in the process.
Can the Motorola factory replace the battery in the H730 headset?
It is possible to have the battery in your Motorola H730 headset replaced, but it would likely need to be done by a third-party repair service as the battery is not typically user-replaceable.
Motorola does not offer an official repair service for the H730 headset, so you may need to find a third-party repair service that specializes in repairing Bluetooth headsets. Be aware that third-party repairs may void any remaining warranty on the device.
You can also consider purchasing a new headset if you prefer not to have it repaired.
I have two older Motorola Walkies Talkabout FR60 wont send or receive and a T5820 with the rubber broken off the antenna is is cost feasible to fix or not
I believe for the FR60 walkie-talkies, if they are not sending or receiving, the issue could be related to the antenna, battery, or internal components. You can try replacing the batteries and/or antennas to see if that resolves the issue.
As for the T5820 walkie-talkie, if the rubber on the antenna is broken, it's likely that the antenna itself is also damaged. In this case, you can try replacing the antenna with a new one. Antennas are typically available for purchase online or at electronics stores.
In terms of cost, repairing older walkie-talkies like these may not always be cost-effective. If the repairs are extensive or require replacement of major components, it may be more practical to purchase new walkie-talkies instead.
Below are options of the options of walkie-talkies you can buy;
Motorola sliver headset won't power on even when the green lights are solid
There are a few things you can try to troubleshoot this issue with your Motorola Silver headset not powering on:
- Make sure that the headset is fully charged by connecting it to the charger for at least 30 minutes.
- Check the battery contacts in the headset and charger to ensure that they are clean and free of debris.
- Try resetting the headset by holding down the power button for 15 seconds.
- Try a different charger or charging cable to see if that resolves the issue.
- Make sure that the headset is not in pairing mode.
- Check the headset manual for any information regarding troubleshoot, or if there are any specific instructions for turning on the headset.
If none of these steps resolve the issue, it may be a problem with the headset itself and you may need to contact Motorola for further assistance.
Please note that the information provided is based on my knowledge cut-off date and it may not be current.
Can you use the Motorola XPR 4550 as a police scanner?
The Motorola XPR 4550 is a two-way radio, not a scanner. Scanners are devices that can listen to a wide range of frequencies, whereas two-way radios are designed for communication between a limited number of specific devices on specific frequencies. However, you can use a scanner to listen to the frequency that the Motorola XPR 4550 is transmitting on.
