20 Most Recent
Dell Inspiron 531s Notebook Questions & Answers
How torun a flat panel hd lcd tv on a dell 531s
Please check the input ports on the LCD TV and the output ports on the computer's video card. You need to have a proper cable (VGA, HDMI or DVI) to connect your computer with your LCD TV. Later you need to select your TV's input mode.
Unable to connect to facebook
Maybe you have been blocked? Have you tried another broswer, Google Chrome, Firefox, Opera, Pale Moon, Comodo, Safari? etc.?
Cant sing on to messenger
Maybe you don't know to sing :) However try to download newer version. And maybe just re-think your password twice.
Dell error code OFOO:137b
try to check the ram of your computer....turn off your computer....removed the ram. and place it again.. but if still doesnt work.. maybe try another ram.. just borrow first. to try it.. and if it will work.. you can buy a new one.....GOOD LUCKhope this can help..!! thank you
Windows XP Boot Up
USB Keyboard take a while to register. Try a serial type keyboard if your system has the Purple serial port on the back.
SOUND off
The speakers need to be connected to the stereo audio out jack, it has a green color code on the output jack.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
