20 Most Recent HP 16 GB USB FLASH DRIVE PRO FULL SPEED 2.0 Server Questions & Answers
NO LAPTOP STATED.
ok what are you doing, tell that first. the job at hand.
then tell symptoms.
omg , i can buy generic USB memory sticks in a bundle at Walmart check out. the all works on every PC made.
so do yours.
did you try this stick on other PCs, (NOT WITH XP )
you do XP is a dead OS not for 3 long years, right
and plug and pray is not dead at HP , and MS. right?
for XP to work , (good luck there)
it must have SP3 loaded, does it?
and be connected to the internet ; are you.
XP will try to find the USB drivers to run your stick as ALL OS do the first time, and XP will fail. in most cases now
that is because microsoft pulled the XP plug. 3 years ago
that means they only have 1 tiny bit of support left,
that is activation, only
time to up grade to w7, for sure
or go to GOODWILL Buy pc used with W7 COA sticker on the bottom for $20 and win.
this is the support in the STICK.
https://support.hp.com/us-en/product/HP-Brand-License-USB-Flash-Memory-series/3261337/model/4077082
HP 16 GB USB... | Answered on Aug 08, 2017
Check this pen driver on different pc may be your pen driver faulty
HP 16 GB USB... | Answered on May 05, 2014
Usually, a USB drive that says it is write-protected is protected by a password set by the owner. If you cannot open it you cannot format it. You need the password. Look on the Internet for some software that can remove, reset, or retrieve the password.
HP 16 GB USB... | Answered on Dec 18, 2013
seems to be to be u have not connected it correctly
or just fresh restart ur system and try it again it works
HP 16 GB USB... | Answered on Feb 16, 2013
check drivers
HP 16 GB USB... | Answered on Jan 30, 2013
My new Hp v165w 2GB pen drive can not copy file from my PC
HP 16 GB USB... | Answered on Aug 09, 2012
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
HP 16 GB USB... | Answered on Jul 20, 2012
To password protect a USB flash drive the best way is to go for the encryption option so if its lost you are still protected has many are still accessible if lost.
http://www.truecrypt.org has the free software and instructions but you will have to copy your files to a pc first and then copy back when the drive is protected
HP 16 GB USB... | Answered on Apr 05, 2012
i have hp v165w 2gb
when i tried to format it ,it gves an error of write proection
HP 16 GB USB... | Answered on Sep 16, 2011
Hi
Please describe you problem properly
Thanks
HP 16 GB USB... | Answered on Jul 26, 2011
I see.... very interesting. Take it back and get your money back to buy a new one.
HP 16 GB USB... | Answered on Jul 01, 2011
if you want to recover your data you open the google and type data recovery vizard open the site and download it.After Installing software,you can recover your all data.
HP 16 GB USB... | Answered on Jun 07, 2011
Please check if it has any lock (a small latch in the side usually) that may be preventing the format.
HP 16 GB USB... | Answered on Mar 06, 2011
Start->Run and type "diskmgmt.msc" then right-click the drive and select "Change drive letter and Paths" and change the drive letter to something completely different like T: or W:.
HP 16 GB USB... | Answered on Feb 28, 2011
There could be a problem with the hardware itself,You should take it back to where you bought it..
Thank you,Please Rate me max :)
HP 16 GB USB... | Answered on Feb 01, 2011
If your system did install the HP software/drivers for this pen the first time you connected, try reinstalling the drivers, reboot your system and try again.
Good Luck
C2Solutions
HP 16 GB USB... | Answered on Jan 22, 2011
HP 16 GB USB FLASH DRIVE PRO FULL SPEED 2.0  Server Logo
46 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp v165w 2gb usb device
  • Computers & Internet
