20 Most Recent Seiko S149 Stopwatch with Built In Printer Questions & Answers
My seiko s149 with built in printer went blank the other day.
The S149 has 2 sets of batteries
1) 4 X AA for the printer
2) a round "button battery inside the unit for the clock.
Open up the unit, you will see that it takes either a 2450 or a 2032 depending on the model.
7/6/2022 4:13:08 PM • Seiko S149... • Answered on Jul 06, 2022
3answers
Seiko Stop Watch S149
If you go to "www.sportscounters.com/seiko-s149-stopwatch-printer-all-in-one" you will see a telephone number, try calling them for advice.
(This problem is fairly common after replacing batteries, so I suspect that there is a procedure for resetting the timer.)
10/19/2016 1:27:10 PM • Seiko S149... • Answered on Oct 19, 2016
2answers
I have a seiko stop watch s129 that only has a
The LCD is having issues. The Seiko Service Center is the only place to repair this watch. Contact them at:
(800) 722-4452
10/18/2016 5:41:38 PM • Seiko S149... • Answered on Oct 18, 2016
Replace printer ribbon
Print is very faint on thermal paper Seiko System Stop Watch S149
9/25/2013 4:51:58 PM • Seiko S149... • Answered on Sep 25, 2013
I replaced the stop watch battery. Now I get all zero's and the stop watch or date does not work
Look for a reset, check the instructions
10/12/2012 3:55:26 PM • Seiko S149... • Answered on Oct 12, 2012
2answers
Replaced batteries but stopwatch will
mcdevito75 here, Try re-setting the entire watch, re-set everything, hour, minute, day, date etc.
10/30/2011 2:18:01 AM • Seiko S149... • Answered on Oct 30, 2011
I replaced both sets of
I'm assuming that you have the correct thermal paper and it was installed correctly as explained in the manual at page 7.
If this is the case then the defect is hardware. To find out where the defect is located you must do a simple test by pressing the paper advancing switch. If the paper doesn't move then the paper mechanism has failed and it will have to be replaced - only a Seiko dealer can do that since they are the only ones that have spares, you will have to send it to one. If the paper moves then the defect is in the print unit - there are no spares for it, the unit is dead.
6/1/2011 4:28:40 PM • Seiko S149... • Answered on Jun 01, 2011
0answers
How do i get the
I suggest taking the item to a watch repair store and have them install it for a min. cost, some will change the battery right on the spot. The other option is to get the proper tool called a case opener that will take the watch case off. go to www.ebay.com and type watch tools, there you will find all kinds of case openers that have fixed sizes and adjustable ones.
12/31/2010 3:22:05 AM • Seiko S149... • Answered on Dec 31, 2010
Watches Logo
28 questions posted
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
View Most Popular
Seiko Watches
  • Seiko Watches
Most Popular Question
seiko s149 built in printer went blank
  • Watches
