20 Most Recent Samsung BL103 Digital Camera Questions & Answers
Did you try Samsung.com? Make sure your computer/laptop has Adobe Acrobat Reader so you can view it on your computer. http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=digitalcameras&type_cd=04010000&subtype=blseries&subtype_cd=04010100&model_nm=SAMSUNG+BL103&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=04010100&disp_nm=BL103&isEqualsY= Direct download: quick start manual: ver.1.0 English http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2144491&CDCttType=EM&ModelType=C&ModelName=SAMSUNG%20BL103&VPath=EM/200812/20081230110036531/BL103_QSM_F1.3_080731.pdf user manual ver.1.0 English http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2049189&CDCttType=UM&ModelType=C&ModelName=SAMSUNG%20BL103&VPath=UM/200810/20081031132341750/BL103_English.pdf
Samsung BL103... • Answered on Oct 22, 2018
It's broken get a new camera.
Samsung BL103... • Answered on Apr 19, 2016
All SD cards has a physical switch that locks the card. Remove the card from the camera and check this switch. It's on the left side of the card opposite side the angled edge. Make sure that the switch is in the forward position (towards the pins that get seated in the camera). Replace the card in the camera carefully to avoid moving the switch. Try accessing the card again. If the switch is damaged or slides back and forth to the locked position easily, replace the card. It's possible to temporarily fix the card to access it. You need to carefully cut the switch plastic away from that slot and then cover the slot with tape. Make sure that the tape lies flat against the card and doesn't cover the area with the pins. I hope this helps. Cindy Wells
Samsung BL103... • Answered on Apr 27, 2014
1. Select the MANUAL mode by rotating the mode dial. 2. Press the Fn button and menu for the shutter speed and aperture value will display. Up / Down button : changes aperture value Left / Right button : changes shutter speed. 3. Press the Fn button twice and take an image.
Samsung BL103... • Answered on Apr 01, 2014
Do you mean you can't download pictures?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Samsung BL103... • Answered on Feb 20, 2013
To delete all the pictures on the memory card, format the card. To delete all the pictures in the internal memory, format the internal memory.
If it's a day game, use the Sports setting. If it's a night game, turn off the flash, turn the ISO up as far as you can, and cross your fingers.
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You don't need to install your camera in order to use it.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
See the instructions on page 47 of this manual.
See the instructions on page 69 of this manual.
Samsung BL103 Digital Camera Logo
129 questions posted
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Eric
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
looking instruction book samsung 10 2
  • Cameras
