20 Most Recent
Canon IXY Digital 700 Digital Camera Questions & Answers
Canon 700 black screen
sounds like the ccd is not working usually new lens unit required
almost make it uneconomical to repair
6/14/2014 10:54:33 PM •
Canon IXY...
Answered
on Jun 14, 2014
How to restart the camera
Very easy. Remove the battery. make sure it is charged, before you reinsert it. When the battery is charged, you can reinsert it after a few seconds. This will cause a cold start of the camera.
This works with every digital camera. When the camera does not start, recheck the battery (batteries) and the battery housing in the camera, if all contacts are clean and shiny. If the battery is really in good order and charged, the camera must be defect. Then con act the service centre closest to you.
2/12/2014 8:01:46 PM •
Canon IXY...
Answered
on Feb 12, 2014
Card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
10/17/2013 7:08:34 PM •
Canon IXY...
Answered
on Oct 17, 2013
SOLUTION FOR E18
http://www.e18error.com/Please read the info on this website and proceed at your own risk. The problem is something is not allowing the lens to move I believe. It seems to be an issue in a number of cameras listed at the site as well. You did not tell me the model of your camera.
9/8/2012 2:33:06 PM •
Canon IXY...
Answered
on Sep 08, 2012
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/20/2011 4:40:01 PM •
Canon IXY...
Answered
on Sep 20, 2011
Canon IXY white screen problem
Does the white screen appear all the time or does it appear only when you are trying to take a picture? Also are you able to bring up the menus and see them even when the white screen is there? This info will help me confirm if its a problem with the imagesensor or the LCD screen so please let me know.
Sai.
9/10/2011 2:18:05 AM •
Canon IXY...
Answered
on Sep 10, 2011
When i want to turn
Unfortunately, restarting the camera rarely corrects a lens error problem. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
7/28/2011 1:29:50 PM •
Canon IXY...
Answered
on Jul 28, 2011
My canon ixy digital 510IS
Possible that the main board has failed the main controller unit. Please check the battery and the VOLTAGE on it by using a good multimeter. If low try and charge or if the charge does not develop then the battery is faulty, It is important that there is enough CURRENT capacity on the battery to switch on. if so test with one before you confirm,
7/18/2011 7:48:43 AM •
Canon IXY...
Answered
on Jul 18, 2011
When I turn on the
That usually means that your batteries are too low to run the camera. Try changing the batteries.
7/14/2011 11:20:28 AM •
Canon IXY...
Answered
on Jul 14, 2011
Hi
I am turning on
Canon E18 error happens when the lens gets stuck while trying to extend.
The camera will beep a few times and the LCD will display a little E18
in the lower-left corner. The lens gets stuck in the extended position,
and refuses to move either to focus the lens or to retract when powered
off.
The problem usually happens because dirt or sand get into the lens mechanism.
Instructions
If your camera is still under warranty, the best thing you can do
is to take it to the nearest official Canon repair shop and Canon should
fix it for free.
If your camera is out of warranty, or if Canon refuses to repair
it for free (happens sometimes if for example they suspect the
camera has not been treated properly) you can try some of
the methods listed here to repair it yourself. These simple methods
have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry
compressed air (20 lbs) set the tip between the lens turret and the
camera body and turn on the air while moving the tip around the lens. It
should remove all dust and sand. Turn the camera on and it should
function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very
often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and
the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to
fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a
"click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the
camera off. Take the camera in one hand and with the other gently take one part of the lens and gently
move it round in a circular movement. Do so with both sections of the lens. You will hear a "click"
as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning
the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and
off and take lots of pictures, close ups and distance. Focus should slowly start improving.
6/26/2011 3:59:47 PM •
Canon IXY...
Answered
on Jun 26, 2011
I'm wondering if I changed
If you haven't intentionally changed the settings you can try restoring it to factory default settings. That should undo any changes you've made and rule out settings as a cause of the problem. I don't have a menu walk-through for this model, but the factory reset is generally in the menu towards the end of the settings.
If that isn't an option here are a few settings you can check that can cause this effect: 1. ISO - This is how sensitive the camera is to light. You probably want it set to a lower number or preferably Auto. If its set at 400 or above it can cause wash out in bright lighting.
2. EV / Exposure Value. You can usually adjust the exposure value in increments of .5 or .33 from -2 to 2. If it is set towards two it can cause over exposure and odd coloring. 0 is generally best for everyday shots.
3. WB / White balance - This lets you set custom or preset colors as the base "white". Make sure its not set to custom and it is set to something appropriate for your environment (auto is best if available).
4. Also make sure the camera isn't set to long exposure or night mode as both of these settings can cause washout.
4/21/2011 2:04:15 PM •
Canon IXY...
Answered
on Apr 21, 2011
I cant turn on my camera even if the battery is
The
symptoms are those of an internal hardware failure. The camera starts
up, indicating that it is powered. Then it shows the splash screen,
which says that the LCD is working. Then the camera crashes while doing
the initial test, when all part of the camera are powered and checked.
When
it fails this way it is usually defective main board. A short in wiring
to lens or a shorted lens motor may cause the same thing. Before
sending the camera for repair, check the following.
Test using a
different battery . You can go to a
camera shop and ask testing battery.
If you are using ordinary batteries, ensure that they are Alkaline. Replace with fully charged.
Try starting the camera with no memory card. A shorted SD card may cause the same thing.
Check if the lenses are stuck half the way through.
Remove
batteries; point lens to the floor; hold down the on button; reinsert
batteries while holding the button; release button (power reset).
If
all that does not work, then the camera must be repaired. In that case
call manufactured to get a quote on repair. You can get a quote from a third
party here:Repair.
2/25/2011 1:38:39 PM •
Canon IXY...
Answered
on Feb 25, 2011
Lens error what da problem?
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
2/9/2011 2:44:56 PM •
Canon IXY...
Answered
on Feb 09, 2011
I brought a Canon IXY to Abu Dhabi. I bought it
The camera does have a USB port, but the connection at the camera end is a miniature socket. Sounds like you didn't bring the cable with the mini-plug at one end and the full-size USB plug at the other. You may be able to get the right cable where you are, but there are several different sizes of the mini-plug end.
The other, and easier, way to get the pictures is to just take the memory card out of the camera and put it in a card reader attached to the computer, especially now that these readers are built into computers and printers. The card then appears in "My Computer" as a removable drive and you can just drag and drop the pictures onto your laptop. You can't get the pics from the camera's internal memory that way though.
If your laptop doesn't have a card reader, you can pick up an SD card reader in what we in the UK would call a "pound shop", or in Japan a 100 yen shop.
1/26/2011 4:28:05 PM •
Canon IXY...
Answered
on Jan 26, 2011
Error in on/off switch,lcd shown E18
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
center for a evaluation to see if it would cost more to repair than to
replace the camera.
Hope
found this helpful.
Regards
Andrea
12/19/2010 8:42:40 PM •
Canon IXY...
Answered
on Dec 19, 2010
The lens failed to restract...how can i fix
Hi, this is a lens assembly mechanism problem. It is a delicate part of any camera. The lens assembly is composed of several servomotors, coils, some sensors and the actual lens. It does the following jobs:
it extends the lens back and forth
achieves focus by moving the lens
zooms the lens by rotating them in the same time as the whole objective is moved back and forth
Each of these operations is controlled by some servomotors who actually move these parts and are also connected to some sensors that pass the readings back to a main processing unit. When you open the camera this processing unit will check to see if the lens assembly is able to do all of these 3 things. Failure to comply with even one of them will result in the error you see which doesn't mean that the lens itself are damaged, could be the connector to their servomotors, sensor failure, some coils that are out of position and things like that. They are all related to the lens assembly. Because this is a VERY fragile part of any camera I don't suggest you to try a DiY repair because you can damage the lens even further. Even service centers have problems repairing this, most time it is done under a microscope and some times it simply can't be fixed.
This problems occur most of the time in corelation with the camera being dropped or received some shocks but it can happen out from nowhere, just like that.
I would recomand you to go to a service center. Try not the big ones that represent large corporations (because they are expensive), instead look for a smaller one. Tell them you have a lens assembly problem, ask them to make you a diagnostic and then ask for a cost estimate BEFORE they actually repair the camera. If the lens assembly is damaged beyound repair it will need to be changed as a whole, including all connectors, CCD sensor and so on. This could cost from $70 - $200 excluding labor parts that can be about $100. Therefore you should ask them a cost estimate.
If your camera is still in waranty you just need to call one authorised service center to have it fixed for free.
12/3/2010 5:19:54 AM •
Canon IXY...
Answered
on Dec 03, 2010
Whats the problem if error 18 appears on the
You are getting this error due to lens problem.
As simple it mind sound, but hitting this on the palm a couple of times
solved the problem. The lens began to retract but continue with the E18
error. Now on continual basis, 5-6 times, while retracting I kept on
the heavy palm tapping, and the problem got resolved. Pls try this
elementary method first. Worked for me.
Hope this helps.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
11/24/2010 3:31:17 PM •
Canon IXY...
Answered
on Nov 24, 2010
