20 Most Recent Motorola Talkabout T5800 (22 Channels) 2-Way Radio Questions & Answers
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Motorola... | Answered on Oct 18, 2011
Depending on the type of microphone used, if not the type using the speaker as a microphone, it may be damaged. I would though, suggest you remove the battery, open the case and allow the innards to dry in a warm place for several days. Even daily exposure to the sun should work fine.
Motorola... | Answered on May 18, 2010
press and hold the + button untill the frequency changes then move up and down to the one you want.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Motorola... | Answered on Apr 25, 2010
A couple of things you can try:
1. Use electronic contact cleaner (spray type) on the PTT switch;
2. Use an external speaker/microphone and/or handsfree VOX headset
3. Replace the PTT switch. 4 solder points. Might not be easy but doable.
The last would require that you remove the defective PTT switch and use that as per sample when looking for replacement. Some printers uses the same type of switch. Familiarity with electronic components/circuitry, use of a DVM and a soldering iron would also be required.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Motorola... | Answered on Jan 10, 2008
This is likely because your radio's battery has lost enough power that it cannot fully power the headset and the radio both. Or there is a component in the headset or radio which is getting overheated and will not function properly. Try the headset on another radio at the time of failure and see if it is still in failure mode on the other radio. Or try changing the battery to a fully charged battery and see if the headset then functions correctly. These test will help you determine which component is failing.
Motorola Radio... | Answered on Mar 11, 2020
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on Nov 03, 2019
please, try long press P2 button, to unlock your radio,
and re-try,
Thank you,
With Regards,
jack
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
Motorola Radio... | Answered on Oct 04, 2019
Entering Front Panel Feature and Button
Configuration Mode
If your radio is turned ON, turn it OFF. Press and hold the side
programmable button 1, and turn your radio ON. A tone is
heard, indicating that your radio is in Feature and Button
Configuration Mode. The indicator illuminates and the
"BCKLIGHT" is displayed on the radio LCD screen.
Whenever the radio is turn on, it initiates a self-test routine which checks the RAM, EEPROM
hardware and EEPROM checksum. If Self Test passes, the green LED flashes once and a Self-Test
Pass Tone is generated. If unsuccessful, the red LED flashes rapidly and a Self-Test Fail Tone is
heard
You may need the programing software to do the reset the manual does not give you any info on resetting the radio
Motorola Radio... | Answered on Oct 03, 2019
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Motorola Radio... | Answered on Sep 26, 2019
Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
Motorola Radio... | Answered on Sep 20, 2019
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Motorola Radio... | Answered on Aug 31, 2019
Motorola Talkabout T5800 (22 Channels) 2-Way Radio Logo
6 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
talk about frequency change
  • Radio Communications
