20 Most Recent Motorola Talkabout T5320 (14 Channels) 2-Way Radio Questions & Answers
Constant static on motorol t5320
Reprogram your Radio
7/11/2016 4:51:41 AM • Motorola... • Answered on Jul 11, 2016
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
2/16/2016 11:57:22 PM • Motorola... • Answered on Feb 16, 2016
3answers
How do I change the channel on my T5320 2way
With the radio on press the MENU button. The current channel will begin to flash. Use the + or - button to change the channel while it is flashing. Press the PTT button to lock in your selection.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T5300_T5400_User_Manual_E.pdf
8/4/2009 2:37:25 PM • Motorola... • Answered on Aug 04, 2009
Motorola Elite Sliver will not charge or connect red light keeps blinking
I have a Motorola elite sliver and know it won't turn on and it doesn't want to connect I want to know if I can fix it thanks
11/27/2021 7:47:07 PM • Motorola Radio... • Answered on Nov 27, 2021
Hai Lu Hong earbuds. How can I connect both earbuds to my Motorola G5?
Try the attached links you should be able to download the manual. https://www.motorola-support.com/uk-en/?page=device/motorola/moto-g5
10/25/2021 1:30:56 AM • Motorola Radio... • Answered on Oct 25, 2021
Motorola talkabout red light on radio stays on while charging
Your radio needs to be turned off when on the charger, and be certain you are using a rechargeable Motorola battery. The charger will not charge AAA batteries or rechargeable style AAA batteries. If the light does not illuminate on your charger, try the radio in a different charger and see if it does. This will tell you if it is the radio or the charger. One further note, you should clean your charge contacts with a pencil eraser to insure they are making good connection.
8/18/2021 3:50:15 PM • Motorola Radio... • Answered on Aug 18, 2021
Program manual for motorola astro spectra w7 vhf
Astro Spectra radios are only programmable using Motorola proprietary software. (Subscription based from Motorola) They do not supply instructions other than what is within the help section of the software.
8/18/2021 3:46:21 PM • Motorola Radio... • Answered on Aug 18, 2021
My Motorola T5500 will not receive; transmits fine
Check your code. It is possible you have the code set differently between your radios.
8/18/2021 3:44:47 PM • Motorola Radio... • Answered on Aug 18, 2021
Need Motorola GP3188 Programming Software.
It is mentioned on here, but I don't like the look of some of these sites. The videos may help. https://www.google.com/search?q=Motorola+GP3188+Programming+Software ..
6/19/2021 4:09:28 PM • Motorola Radio... • Answered on Jun 19, 2021
Talkabout T5320. Why is mic not working and I can't hear others talk BUT can page/call others?
It might be that the person or persons on the other end have radios with t Eliminator Code , I call it a pl tone, anyway, if they have theirs turned on they will not be able to here you, this radio that you are using does not have this option. It is like a privacy code that if you dont send the same code they wont here you. Like a locked coded squelch. Even though you are talking they wont here anyone unless they are sending the same code. https://motorola-radios.com.br/catalogos/manual_t5320_t5410_t5420.pdf
3/7/2021 10:46:43 PM • Motorola Radio... • Answered on Mar 07, 2021
I found a motorola bluetooth n136. Will it work with my iphone?
Yes it will. Here are the instructions for pairing it.
How to Pair a Motorola N136 Bluetooth Headset ' Techwalla
www.techwalla.com > ... > Entertainment
The Motorola N136 headset, which has been updated as the nearly identical HS850, gives cell and smartphone users wireless hands-free usage with Bluetooth ... ..
12/6/2020 9:19:17 PM • Motorola Radio... • Answered on Dec 06, 2020
Can you listen to your playlist on Motorola h681 headset
I am not sure about this Motorola device but usually, it's possible to listen to music even on cheap chinese BlueTooth headsets.
8/26/2020 5:56:05 AM • Motorola Radio... • Answered on Aug 26, 2020
Motorola CLS 1110. headset audio gets very quiet (whisper levels) after a few hours of use. it works perfectly for the first couple hours. I have tried reseating the headset, powering on and off.
This is likely because your radio's battery has lost enough power that it cannot fully power the headset and the radio both. Or there is a component in the headset or radio which is getting overheated and will not function properly. Try the headset on another radio at the time of failure and see if it is still in failure mode on the other radio. Or try changing the battery to a fully charged battery and see if the headset then functions correctly. These test will help you determine which component is failing.
3/11/2020 4:04:47 PM • Motorola Radio... • Answered on Mar 11, 2020
??dear i need Motorola Talkabout MR350 schematic ?or service manual i need to make maintenance and i do not know how figure out without the schematic?
Schematics were never released to dealers for the TalkAbout line of radios.
3/11/2020 3:54:30 PM • Motorola Radio... • Answered on Mar 11, 2020
Motorola Talkabout T5320 (14 Channels) 2-Way Radio Logo
Popular Tags
7 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
change channel t5320 2way
  • Radio Communications
